MarkISS
"5th Year" Platinum Supporting Member
Loc: Brevard, NC
Reg: 05-14-18
08-04-22 05:14 AM - Post#2845421
1966 Chevy Impala SS RestoMod. For complete build history, documentation and many more pictures, visit my build link of Chevy Talk @ https://www.chevytalk.org/fusionbb/showtopic.php?t...
I just completed a multi-year frame off restoration and modern upgrades. All new chassis, e.g., So, this classic Impala won't be close to the original except the body and minor modifications to the frame by platting and reinforcement for the increased power and torque. It will be a modern chassis/suspension, the motor is a 434 cu. in. SBC bored and stroked from a new Dart Head block making about ~550 hp and ~530 foot lbs of torque, with a Holley Sniper EFI vs a carburetor. Since this car may be a daily driver, my requirements to the engine builder (Bruce/Brad/Matt at the Engine Factory) were pump gas, good vacuum for power brakes, dual plane intake, and throttle body fuel injection with the highest quality USA made engine components. This power plant will drive through a McLeod RST twin clutch, Tremec TKO 600 5-speed OD manual trans with .64 overdrive and a posi-track rear end. Power brakes, power rack and pinion steering and hydraulic driven clutch are part of the mix also. The Impala SS will also have air conditioning, GPS driven Dakota Digital Speedo, new gas tank from Aeromotive with electric fuel pump built-in, Ceramic coated headers, Magnaflow 2.5" stainless steel dual exhaust, exterior moldings/trims/badging, grill and gauges . For the Impala's interior, I'll be fitting new seat covers, foam and springs, building my own 4 speed console , along with new door side card, handles, Flaming River tilt steering column/wheel, etc. The car has ZERO miles (Facebook lowest miles were 300) Lets talk and make a deal.... PM me or txt or call Mark @ 850-207-7117
Edited by MarkISS on 08-11-22 02:45 AM. Reason for edit: No reason given.
