Username Post: Back wheels get REALLY hot!        (Topic#369094)
bbarr
Reg: 08-01-22
08-01-22 11:52 AM - Post#2845285
The rear wheels get really hot. A laser temp reading runs 150-190 degrees. Pretty hot to touch. Is this normal? Had a brake shop check the brakes (I installed new) to make sure they were not dragging. Maybe it has always been this way and I am just now noticing it.
What would be a normal running temp for the wheels?
08-01-22 11:57 AM - Post#2845286
    In response to bbarr
Model.. Year. Brake type. More info is needed.
grumpyvette
grumpyvette
Loc: farmersville texas USA
Reg: 03-16-01
08-03-22 12:46 PM - Post#2845394
you need a higher quality infrared test gun to provide a second opinion as to the actual temps,
no the wheels do not generally run at that high temp, somethings wrong, you'll want to locate the source of the heat and check all four wheels
maybe you left the parking brake partially on or a wheel bearing is going bad?
cheap works ok
I have a very high quality infrared and several lower quality versions of infrared temp guns, to use in locating issues like that and sources if parts fail.
https://www.harborfreight.com/121-infrared-laser-t...
higher quality sure wont hurt either
https://www.testequipmentdepot.com/extech/thermome...
verify the temp and check the surrounding parts like the differential to locate the higher heat locations as you might find its the differential, or the brakes that are the source of the heat
Edited by grumpyvette on 08-03-22 01:12 PM. Reason for edit: No reason given.
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
08-03-22 03:19 PM - Post#2845399
I do not see 150 to 190 degrees hot by any means. most vehicles have components well above those temperatures without any issues.
There is a certain amount of heat generated from friction whether the brakes are applied or not. You get heat transfer from the differential and some heat generated from the tires running on the road. That heat transfers somewhere.
If it is hot enough to generate a smell, then something is up. Otherwise, I do not see any issues.
Impala_Mike
Loc: Emmetsburg, Ia
Reg: 12-15-01
08-04-22 10:49 AM - Post#2845435
    In response to grumpyvette
I agree on the wheel bearing as being the possible
issue.
I had mine go out and the heat welded the bear to
the spindle, and I had to replace the spindle. Definitely something to look at.
1964 Impala Convertible 327/250 Goldwood Yellow AT,PS,PB,AC,Tilt,AM/FM,Power Seats.
08-06-22 10:29 AM - Post#2845539
how long does it take to get this hot?
how much do you use your brakes?
front brakes should be hotter than rears.
USCGMK1
Loc: San Juan, Puerto Rico
Reg: 07-24-15
08-08-22 07:05 PM - Post#2845642
I had this happen last year on my rear brakes. I just had both sides replaced with shoes, cylinders, etc. Mine just need to be adjusted and if I remember correctly I adjusted the parking brake.
junky
Loc: Northeast CT
Reg: 06-27-10
08-09-22 07:18 PM - Post#2845683
    In response to USCGMK1
Always adjust the parking brake after you adjust the linings. If the cables for the e-brake are taught, then back off of the adjuster till there is slack in them, and then adjust the linings. The next thing to do is to get into the car and depress the brake pedal to make sure that the linings are centered in the drum, by rotating the drum and listening for a very slight drag on the linings. Then you adjust the parking brake to the setting in the assembly manual, and you are finished with the project.
Execution time: 0.1 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:07 AM
