Does any one have a source for the sheet metal piece that is behind the quarter panel and extends for ward into the outer rocker on a 64 convertible?
Thanks in Advance
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
62 Imp SS 409 - 5 spd Convertible https://paulstensland.com
62 Impala convertible drivers 1/4 panel -see these pictures -my body shop fixed the existing rust without purchasing new interior rockers.
Looks like you or someone cut out the brace above the rocker in your pictures (see my pictures were the rocker repair is reattached with a patch to the interior brace above the rocker )
Paul
Paul,
Looks like the body shop did a great repair. It was me that cutoff the lower portion of the outer b pillar. It actually went to the bottom of the rocker. It was welded to the rocker at the rocker edge where it turned back down. Did the U channel on the bottom of the rocker get reinstalled?
Brett
Edited by 64Impaler on 08-05-22 02:39 PM. Reason for edit: No reason given.
