2015 Chevy Express 3500. Got error code P1682 that indicated a failure of the Ignition Switch. Got a new one installed per factory manual instructions BUT the lock cylinder will not fully seat in the housing by about 1/4". Key will turn the ign switch but I can not remove the key from the cylinder without the cyl also coming out of the housing.
Tire Design & QA Engineer w/40 years experience.
84 - 96 raced Camaros SCCA & IMSA Endoro series. Won 6 consecutive 24 hour races. Set lap records at 6 different tracks.
Current project - 51 C3100 w/ 88 IROC drivetrain, 80 Camaro clip.
Did you try moving the steering wheel? Does it not lock into place? I can't remember if there is an alignment slot or pin. It can be tricky to get it in there.
Any luck?
'08 GMC Acadia 3.6L SLE
