Username Post: '53 PowerGlide Question        (Topic#369086)
07-31-22 12:10 PM - Post#2845227
I'm asking for a friend of mine. He bought a pretty clean '53 Bel Air and it ran great. But recently the PG won't shift out of low gear.
Any ideas? He said he checked the fluid and it was not low.
drtyler
Loc: Georgia
Reg: 05-06-10
07-31-22 01:24 PM - Post#2845234
The one time mine wouldn’t shift out of Low was due to the fluid leaking out. I was unaware of the powerglide tendency to burp it out due to torque converter leakage.
If you check it cold, it reads ok (if not high). Hopefully your friend knows to check it while running.
07-31-22 02:02 PM - Post#2845235
    In response to drtyler
So you should check it when running and warmed up and in Neutral?
drtyler
Loc: Georgia
Reg: 05-06-10
07-31-22 02:49 PM - Post#2845240
Thats right. Doesn’t even have to be that warm, just run long enough to fill torque converter.
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
07-31-22 02:52 PM - Post#2845241
This is a detail scan of the maintenance guide visor cover placed on all new cars equipped with PowerGlide.
Attachment: PowerGlide_Visor_Maintenance_Guide_Detail.jpeg (2.44 MB) 4 View(s)
1951 Fleetline Preservation
07-31-22 03:01 PM - Post#2845243
    In response to RAM_51
Thanks guys. I just sent Ram's jpg to my buddy.
07-31-22 06:53 PM - Post#2845258
So Type A trans fluid isn't available anymore. Can he use Dexron? Or?
drtyler
Loc: Georgia
Reg: 05-06-10
07-31-22 07:13 PM - Post#2845259
Dex III is fine, as is Dex VI. I have used both.
Dexron VI is backwards compatible with Dexron III. And Dexron III was backwards compatible with the original Dexron ATF, which was the replacement for Type A fluid.
Edited by drtyler on 07-31-22 08:02 PM. Reason for edit: No reason given.
08-02-22 05:34 AM - Post#2845342
Thanks. I told him.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
08-07-22 06:27 PM - Post#2845589
Will not shift out of low..........the fluid has nothing to do with it. Most common cause the govonor gear is stripped. Se shop manual for simple govonor removal.
08-08-22 06:02 AM - Post#2845598
    In response to Gene_Schneider
Thanks Gene. I forwarded the info to him.
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
08-08-22 12:26 PM - Post#2845621
The 62 PG I used in Chebby, would not shift out of Low, and I had to replace the Modulator.
1952 Styleline Sedan, 62-235, Drum brakes, Manual steering, 2" Drop, 8-60 AC, Glass packs, Two Carbs, and a Cast Iron PowerGlide-
Way out behind the Old School
Half a Dozen in a Row, all it needs for Her to go.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
08-09-22 08:34 AM - Post#2845656
If the modlator diaphram is bad on a 1950-1954 you will get a lot of exhaust smoke due to the PG fluid being drawn up into the intake manifold.
08-09-22 12:39 PM - Post#2845665
Thanks. I've passed the messages on.
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
08-09-22 04:15 PM - Post#2845675
I find it interesting that Chevrolet approved a 10W engine oil as a temporary substitute. How things have changed.
08-10-22 06:44 AM - Post#2845694
    In response to Tony1963
I ran 30-wt engine oil in my 1953 Chevy P.S unit back in the day. Worked great.
Tony1963
Reg: 07-09-18
08-10-22 06:47 AM - Post#2845696
I would think that any type of oil that has sufficient lubricating qualities, its compatibility with seals and its viscosity is acceptable.
Today it is almost a sin to not use what is specified and rightfully so.
Execution time: 0.122 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:15 AM
