Username Post: SES light comes on when I put in reverse        (Topic#369085)
4boltmainiac
Reg: 06-13-17
07-31-22 06:21 AM - Post#2845199
My 1990 Suburban V2500 with a 5.7 holley tbi and a th400 trans.
I changed out the cap wires coil to MSD with e3 plugs. Changed out the 02 sensor and the truck runs great. I noticed when I-warm it up the go to put it in reverse the check engine light comes on. I back her out and park then shut the key off and restart her and the light goes out ant the truck runs great again. It just did it again a few hours ago. I left work (not using reverse and no light. I got some food and started it up no light. When i put in reverse the light came on so I pulled over shut her off waited 15 seconds and the light blinked and went out. Drove fine
Please share some knowledge and I sure do appreciate the help
07-31-22 06:35 AM - Post#2845200
    In response to 4boltmainiac
If it did not do this before, look at related wiring that would be affected by the engine rocking only in reverse, check motor mounts that could cause excess movement also.
Chevytech
Chevytech
Reg: 04-25-04
07-31-22 07:32 AM - Post#2845202
Check the trouble codes. If you have not disconnected the battery they codes should be in the memory.
4boltmainiac
Reg: 06-13-17
07-31-22 03:31 PM - Post#2845244
Thank you Shepard
Could you be more specific on like wiring?
New to the tbi th400 set up and waiting on a shop manual to do more reserarch
4boltmainiac
Reg: 06-13-17
07-31-22 03:35 PM - Post#2845245
    In response to Chevytech
Thank you for the info chevytech
Need all the help I can get
Gonna get me an obd 1 tool
Any way to troubleshoot until I get my mitts on one?
Chevytech
Chevytech
Reg: 04-25-04
07-31-22 04:40 PM - Post#2845253
Your welcome!
All you need to read the codes is a jumper wire.
The link I posted in my reply has the instructions on reading codes without a scan tool.
Chevytech
Chevytech
Reg: 04-25-04
07-31-22 04:41 PM - Post#2845254
Edited by Chevytech on 07-31-22 04:45 PM. Reason for edit: The board made a double post
07-31-22 06:07 PM - Post#2845255
Generally go back over the process you went through doing any recent repairs, look for something pinching a harness or when going into reverse pulling on a connector. As mentioned a obd 1 scan may show a code that can steer you onto something, no quick answer from our desks of course.
Execution time: 0.108 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:08 AM
