Username Post: Rear Tire fender Clearance        (Topic#369080)
judd55
judd55
Loc: British Columbia
Reg: 07-04-06
07-30-22 01:36 PM - Post#2845163
I have a '51 Business coupe and am having rear tire clearance issues I have a 80's Camaro rear end with 17"x 8.5"wide billet wheels with 245/45R17 The issue is with the thick inner piece inside of the fender, I assume is there to accommodate fender skirts. My question is.....Can this be ground down perhaps 1/4" for tire clearance.
51 Chevy
55 GMC
55 Wife
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
07-30-22 04:12 PM - Post#2845174
    In response to judd55
Sure, it can be altered / made thinner. One thing I learned in economics class, however, was that for every decision, there is an UPSIDE and a DOWNSIDE. That box section is there to provide structural support for the quarter panel from forces that are applied at the wheel opening; either from the inside or the outside. UPSIDE...your tires may not interfere anymore. DOWNSIDE...the support, made less structurally sound, may no longer provide the support required if the wider wheels do make contact with that area because of spring flex etc.
Just to give you an idea of what kind of surgery you'd be facing...here is an image of the wheel house construction. Maybe a little more involved that one might initially assume:
Attachment: 1951_Chevrolet_Wheel_House.jpeg (85.71 KB) 4 View(s)
1951 Fleetline Preservation
judd55
judd55
Reg: 07-04-06
07-31-22 07:51 AM - Post#2845206
    In response to RAM_51
Thx for the info Ram_51 appreciate the feedback, I'm going to try a slightly smaller tire size first,
Has anyone else run into this problem ?
51 Chevy
55 GMC
55 Wife
52HardTop
Loc: North Haven, Connecticut
Reg: 05-09-04
07-31-22 09:07 AM - Post#2845210
Your choice in rear was a little wide. The early Camaro or Nova rear is what you wanted. Of course, it might have been hard to find? The S-10 4X4 rear is another choice some have used.
2011 Camaro SS 426 HP, Red Jewel Tint. Killer!
52 Bel Air a traditional 50s Ride.
51 Convertible a 60s Ride.
51 1/2 Ton pickup soon to be a little of both..
1999 C-5 Corvette Convertible. Mid Life Fun..
judd55
judd55
Reg: 07-04-06
07-31-22 11:40 AM - Post#2845222
Thx for the additional info, I understand the wheelhouse a bit more now, the biggest issue is the square nuts retaining the inner piece. I may look into simply grinding those down a bit, but not entirely off, so they don't rub the tire.
51 Chevy
55 GMC
55 Wife
RAM_51
RAM_51
Reg: 12-28-02
07-31-22 01:15 PM - Post#2845232
The square nuts are inside the quarter panel; between the inside of the quarter panel skin and the wheel house. Maybe the best you could do is cut another panel that is completely flat (no raised ribs) and secure it to the opening "somehow" instead of using the 7/16" bolts...tack weld perhaps... I just scanned this photo the other day. It pretty much shows the wheel house without the quarter panel attached.
Attachment: 1951_Business_Coupe_Open_Right_Quarter.jpeg (582.59 KB) 4 View(s)
judd55
judd55
Reg: 07-04-06
07-31-22 01:20 PM - Post#2845233
Great idea, I'll look into that for sure, Thx
51 Chevy
55 GMC
55 Wife
coachfrank
coachfrank
Loc: washington,pa
Reg: 07-20-11
08-03-22 11:17 AM - Post#2845392
I had the same problem with my 52 Styleline coupe! I am running 235/70/R15's ! It seemed that the car had lowered itself and that inner fender panel was rubbing on the tire! Replaced the shocks, that didn't solve the problem! Cut the brackets off the inner panel you are referring to, didn't work! Had someone tell me to check the shackle end of my Posie slider springs. The shackles were almost parallel to the ground, loosened the shackles, took a crowbar and pulled them to almost upright to the ground! Must have gained almost 3 inches of fender height! No more rubbing on the tires! I can take pics if you want! Hope this helps!
1975 Corvette, Original owner
1953 Chevy 3100 Pickup
1952 Chevy Styleline Coupe
http://sites.google.com/site/bluejaygarage/
08-03-22 01:01 PM - Post#2845396
    In response to coachfrank
Same thing happened to a friend's 53, he thought that was the way were, he had jacked up the rear from the frame rails, that caused them to rotate down.
Edited by Shepherd on 08-03-22 06:08 PM. Reason for edit: No reason given.
coachfrank
coachfrank
Loc: washington,pa
Reg: 07-20-11
08-04-22 09:56 AM - Post#2845432
I have attached some photos to show how much difference rotating the shackles made
Attachment: IMG_1699.jpg (211.94 KB) 0 View(s)
Attachment: IMG_1724.jpg (198.37 KB) 0 View(s)
Attachment: IMG_1725.jpg (317.76 KB) 0 View(s)
08-04-22 11:19 AM - Post#2845436
Imho, that is not correct, if you hit a large dip in the road they can rotate back to the original position, plus it is putting more stress on the rearward part of the spring. If the rear is no longer a torque tube, the pinion angle can be affected.
coachfrank
coachfrank
Loc: washington,pa
Reg: 07-20-11
08-04-22 11:58 AM - Post#2845438
Shepherd,Go to YouTube and follow the instructions for installing springs on a 1952 Chevy Styleline Coupe and you will see it is now Correct!!!!!!!!!!!!!!!
08-04-22 12:17 PM - Post#2845439
2 never touched 50 Chevs in my shop, they both are in the up position. The oe shop manual shows them in the up position, Posies shows their sliders in the stock up position, maybe they will work the other way, but the info says up is correct.My 51 has been since I own it. Should be an interestingly topic of discussion.
arkansas
Loc: arkansas
Reg: 09-26-06
08-04-22 01:43 PM - Post#2845443
I'm running a '78 firebird rear in my 49 coupe with 235/70 R15's. With the backspacing on the junkyard steelies, I found that if I hit a big bump, the tires would rub. I removed the wheels, jammed a floor jack in there sideways against the frame and jacked the wheelwell out a little then used a mallet and 2x4 to hammer the outside of the wheel opening back in flat. Essentially crushing the spacing between the inner and outer fender a little bit. Problem solved. Haha!
1949 Deluxe Coupe 400sbc, 700r4, 3.73 posi
1949 4D Fleetline Special, all original
1949 2D Fleetline Deluxe parts
1971 Chevy 1/2 ton SWB, 250 I6, 2004r, underconstruction
1926 Ford T bucket, 250 Chevy, T350 tranny
1972 El Camino, all original
Edited by arkansas on 08-04-22 01:44 PM. Reason for edit: No reason given.
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
08-04-22 05:01 PM - Post#2845459
Either way, CoachFrank, that Chevy is a beauty!
Dean50
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
08-04-22 05:05 PM - Post#2845460
    In response to arkansas
There ya go...more than one way to skin that cat.
Dean50
coachfrank
coachfrank
Loc: washington,pa
Reg: 07-20-11
08-04-22 07:09 PM - Post#2845472
    In response to Dean50
THANKS DEAN!!
52HardTop
Reg: 05-09-04
08-05-22 06:42 PM - Post#2845525
I'm at a bit of a loss here. Why modify what is essentially stock parts on these cars only to fit a rear end that is too big for the car? The 80s Camaro rear is too wide. Just looking at the car it is easy to see. When the stock rear came out, the thing would have been to measure its width and use that dimension for the replacement rear.
coachfrank
coachfrank
Loc: washington,pa
Reg: 07-20-11
08-05-22 07:35 PM - Post#2845528
    In response to 52HardTop
I have a 56 rear end in my car that replaced the original rear and torque tube! It is almost a perfect fit width wise! My problem was the rear tires are a little to big! I installed Posies super slider rear leaf springs years ago! I put new gears in the rear last year and I must have caused the rear spring shackles to move which caused the rear fender to drop about 2 inches and the inner fender was slightly rubbing on the tires. I called Posies the other day and they told me to rotate the shackle to get the clearance! I followed recommendations from this site on the use of a 56 rear end in my 52!
judd55
judd55
Reg: 07-04-06
08-05-22 07:58 PM - Post#2845529
Sometimes ya gotta go with what ya got, the entire drive line is from an 86 IROC and the frame and springs have been upgraded as well, so the shackle trick will not work for me, but Thx for the tip, none the less, I have since went from 245/45R 17's to a 235/55 tire which is .6 of an inch narrower and 1" taller, I also ground down any high spots and the square receiver nuts so there are no sharp areas to contact the tires. It is still a bit dicey, but no rubbing so far. The other option is to have the wheels CNC'd to get a bit more offset, there is plenty of meat there to do this
51 Spring Shackle by , on Flickr
51 Chevy
55 GMC
55 Wife
Execution time: 0.082 seconds.   Total Queries: 20   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:17 AM
