Username Post: oil galley plug size        (Topic#369061)
Rwalker
Loc: Rockwell N.C.
Reg: 01-17-14
07-28-22 05:24 AM - Post#2845042
Does anyone know the correct size of rear oil galley plug on 57 283. The hole size is .512.
Rwalker
lizbeth
lizbeth
Loc: Az,desert rat
Reg: 06-22-03
07-28-22 04:19 PM - Post#2845063
    In response to Rwalker
GOING FROM AN OLD AND FAILING MEMORY= I THINK THE ONE I DID BACK IN 1965 WAS COMMON OLD 1/2 INCH PIPE PLUG.. HOPE SOMEONE WITH NEWER KNOWLEDGE WILL CHIME IN SOON.. WAYNE (ELIAZBETH)
OLTYMERZ
Rwalker
Loc: Rockwell N.C.
Reg: 01-17-14
07-29-22 01:33 AM - Post#2845090
    In response to lizbeth
Thanks for the reply Wayne. 57 had press in plugs. I may have to drill and tap for a pipe plug but engine is together in car and would be scared to get metal shavings in oil passages. I was hoping to replace the press in plug that was leaking. Been to NAPA and several engine machine shops and each had different sizes (.512 to .534). Thanks again.
Rwalker
lizbeth
lizbeth
Loc: Az,desert rat
Reg: 06-22-03
07-29-22 05:12 PM - Post#2845130
SORRY, I MUST HAVE BEEN THINKING OF SOMETHING ELSE.. ARE YOU SAYING IT IS A FREEZE OR EXPANSION TYPE PLUG?? ANY GOOD/OLD AUTO PARTS MAN SHOULD BE ABLE TO LOOK IT UP..
OLTYMERZ
Rwalker
Loc: Rockwell N.C.
Reg: 01-17-14
07-30-22 01:06 AM - Post#2845136
Thanks, your thinking is correct. Sometime in the late 60's or early 70's Chevy went to the screw in pipe plugs, before that had the press in plugs. I think what the parts places and machine shops are giving me are freeze plugs, which are different size. I may have to drill and tap for 3/8 npt plug.
Was hoping to find the correct press in plug size.
Thanks again,
Rwalker
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
07-30-22 02:48 PM - Post#2845169
You are referring to the oil gallery plug or the rear cam plug?
Rwalker
Loc: Rockwell N.C.
Reg: 01-17-14
07-31-22 05:19 AM - Post#2845197
    In response to Tony1963
the three oil plugs above the rear cam plug
Rwalker
Tony1963
Reg: 07-09-18
07-31-22 10:23 AM - Post#2845213
Not sure the size but any auto parts store should have them in stock and give you the size.
Rwalker
Loc: Rockwell N.C.
Reg: 01-17-14
08-01-22 02:36 AM - Post#2845268
Thanks for the replies. Found some oil plugs at an old auto machine shop in nearby town. What the parts places and machine shops have been giving me are freeze plugs,which are smaller than the oil plugs. The diameter of the oil plugs are .524.
Thanks again
Rwalker
Execution time: 0.124 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:39 PM
