Username Post: Fan Shroud for 55 V8        (Topic#369039)
brad_bb
brad_bb
Loc: Joliet, IL.
Reg: 07-13-01
07-26-22 03:46 PM - Post#2844965
So, I finished my restoration gosh, almost 15 years ago. Not sure where the time went. 55 Bel Air 2dr HT, 265 V8 2bbl, With PS, and powerglide. All stock. I played with it a few years, not sure but put at least 1500 miles on it. Other things in life took over, but over the next couple years want to get back to it. Still looks great sitting in storage.
One problem I had back then is that I did a parade once, and I was overheating. I didn't have any issue driving around normal.
Is there a reproduction AC fan shroud available these days? I know they didn't have one originally unless it had AC. If there is, will it bolt to my V8 core support? I'm hoping for a nice metal one. Back when this happened I bought a plastic two piece one offered at the time, but never installed it (it just seemed so cheap looking). thanks, Brad_bb
If someone else can design it, I sure as heck can figure out how to fix it!
Edited by brad_bb on 07-26-22 03:58 PM. Reason for edit: No reason given.
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
07-26-22 05:58 PM - Post#2844970
    In response to brad_bb
If the factory didn't use a fan shroud, then you probably do not need that to keep it cool. The fan shroud pulled air across the condenser instead of around it was its main purpose.
My suggestion is to make sure that the radiator is clean and that you aren't adding more heat than the cooling system can design. When the car is moving and you get more airflow, you can cool the vehicle. At idle, you have trouble. Check timing as well.
Site Ambassador
07-26-22 08:56 PM - Post#2844976
    In response to Tony1963
I don’t think Chevy ever put a shroud on any of their cars back in the day, even with air conditioning. They had a different fan with 5 blades instead of 4, but no shroud. Cars from back then had trouble keeping temperature even when new. Overheating was a common occurrence back then.
If it cools okay when you are moving, then airflow is your problem so a shroud should help. Here is a metal one from Classic Industries:
https://www.classicindustries.com/product/1955/che...
1957 Cameo Carrier
brad_bb
brad_bb
Loc: Joliet, IL.
Reg: 07-13-01
07-26-22 10:09 PM - Post#2844979
    In response to wagonman100
It says that shroud is for V8 core support with radiator in V6 position (in front of the core support). I have the V8 core support with radiator in the V8 position (behind the core support) unfortunately.
bolake
Loc: Northern MN
Reg: 09-05-17
07-27-22 05:48 AM - Post#2844993
Summit Racing has a Danchuk #16626A, V8 in V8 radiator position. I put it on my 55, works good
If your not the lead dog the view never changes
Edited by bolake on 07-27-22 05:49 AM. Reason for edit: No reason given.
Belair-o
Reg: 03-26-07
07-27-22 07:31 AM - Post#2844998
    In response to bolake
What the previous poster said. I put that one on my car, it looks factory, and works very well.
brad_bb
brad_bb
Loc: Joliet, IL.
Reg: 07-13-01
07-27-22 08:00 AM - Post#2844999
Thanks, I had not found that metal V8, V8 shroud. Not sure if the diameter is small enough for stock fan but I just ordered it, so we'll see.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
07-27-22 08:14 AM - Post#2845001
I do not have a specific recommendation; I have not owned a '55 this century. But, to function properly, the fan blade needs to 'sit' approx half in and half out of the shroud. So, the distance from the radiator to the fan blade will impact the 'depth' of any shroud you install (along with mating to the radiator and existing fan.
Air flows thru the radiator (bumper side to engine side) because there is a pressure differential. During driving at forward speed, the differential is supplied by out side air being forced against the radiator. At idle/stop and go, the fan creates a 'negative' pressure on the engine side of the radiator. A shroud increases this 'negative' pressure and 'more' flow results.
A fan with more blades (5, 6 ?) will provide 'increased' flow. But w/o a 'clutch' such fans are 'noisier' at higher rpm. Also, w/o a clutch, such fans will 'draw' more torque from the engine to rotate. Torque that could be used for other purposes (propulsion, a/c).
The 'clutch' (if used) also impacts the dimensional aspect of the installation.
Pick based on your priorities. But first I recommend you verify the radiator's functionality.
Just trying to be helpful.
Pete
Site Ambassador
07-27-22 10:15 AM - Post#2845007
Sorry about that. I didn’t notice it was for the radiator being the the 6 cylinder position. It looked like they had several options and I just chose the metal one. Here’s the correct one:
1957 Cameo Carrier
Execution time: 0.133 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:28 PM
