Username Post: Horn contacts for 60 Cevy Impala        (Topic#369036)
Richard Moran
Reg: 07-26-22
07-26-22 09:33 AM - Post#2844944
Had a problem getting horn to operate on 60 chevy impala. Checked chevytalk and noted other people had same problem and could not solve the problem. I worked with the problem for hours and finally solved it. I took an O ring the size of the concave metal disc. Placed the O ring on the steering wheel under the disc, placed the disc concave up, placed the plastic piece in, put the horn ring on and fastened it done, tightening the screws evenly. Not too tight, but tight enough for no play in ring. Tried the horn and it worked everywhere on the ring. I think the main problem was that the weight of the ring was too much causing the horn to blow. By adding g the O ring it helped support the ring and still had enough flexibility to make contact.
Execution time: 0.107 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:12 AM
