Username Post: Fog lights come on automatically        (Topic#368970)
YOUNG57
Loc: Tennessee
Reg: 12-06-10
07-17-22 05:53 PM - Post#2844515
I want my fog lights to come on automatically with the low beams in low light driving conditions for better night time visibility and stay on with the high beams.
Looking at how-tos on YouTube they only show connecting the fog light relay trigger wire (pin #10) to the high beam relay trigger wire (pin #18) on the brown plug at the BCM so they only come on manually when you turn on the high beams or manually push the fog light button.
Or connecting them to the DLR relay trigger wires (pin #22) so they come on automatically anytime the vehicle is in drive, even during day light driving.
Neither of these is what I want. I want my fog lights to come on automatically with the low beams in low light driving conditions
I need the low beam relay trigger wire pin number on the brown plug at the BCM.
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
07-18-22 01:58 AM - Post#2844524
    In response to YOUNG57
The reason that the fog lamps do now come on with the high beams is because your distance vision will be inhibited by the bright forward light of the fog lamps.
That is the reason that they go off when high beams are selected. The fog lamp illuminates the lower front area of the vehicle.
Even my Mercedes turns out the fog lamps when you select the high beams.
Matt
Member #2440
Matt
Loc: SAV
Reg: 09-26-01
07-18-22 11:29 AM - Post#2844568
    In response to Tony1963
@YOUNG57 - what year truck?
My '16 Sierra has a resistor in the fuse box that the fog lamps come on anytime the lights are on. I'll check what it is when I get home if I remember.
YOUNG57
Loc: Tennessee
Reg: 12-06-10
07-18-22 02:05 PM - Post#2844577
    In response to Matt
@ Matt
2019 Yukon
Resistor or diode?
Edited by YOUNG57 on 07-18-22 02:13 PM. Reason for edit: No reason given.
YOUNG57
Loc: Tennessee
Reg: 12-06-10
08-22-22 07:45 AM - Post#2846239
Found answer to my question. Got to love YouTube….
On the brown plug in the BCM (under driver’s side dash), install a diode between the Brown with White Stripe wire in Pin #10 and in the Solid Blue wire in Pin #22. I used T-taps wire connectors on both wires and plugged in a diode between them. So, this reversible without damage.
The fog lights will come on with headlight low beams automatically in low light condition and stay on with high beams. This gives me a lot more illumination to both sides immediately in front of vehicle. They do not come on with the DLR lights or cancel with turn signals.
The only down side is this Yukon has automatic on and off high beam depending on light conditions and on-coming vehicles. With the diode in they are no longer automatic.
Execution time: 0.091 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:33 AM
