Username Post: Need help with wiring        (Topic#368927)
stonecoldtx
Loc: Denton, TX
Reg: 01-16-22
07-12-22 08:36 AM - Post#2844224
Hi, All--
I am installing a Chevrolet Performance "Connect & Cruise" LT1/8L90E into a 57 Chevy Sedan Delivery wagon . . .
I am using a Camaro/ATS shifter, and need to figure out the wiring for the Neutral Safety Switch and the Reverse Switch . . . I have looked at the connector on the shifter, and wiring in it only goes to the Shift Interlock (i.e.: depress the brake pedal before the shifter will move out of Park) . . .
I have tried to find information on AlldataDIY about wiring diagrams that would show me where these components are, but I've come up blank . . .
Can anybody help me get these things wired up? A wiring diagram showing where these are would be helpful . . .
Thanks in advance!
Perry
stonecoldtx
Loc: Denton, TX
Reg: 01-16-22
07-26-22 12:27 PM - Post#2844952
    In response to stonecoldtx
Well, seeing as how there has been 72 views with no response, I'm guessing that nobody here has any answers . . .
AlldataDIY was also no help, so I ordered the 2017 Camaro Shop Manual from Helm . . . hopefully, it will have what I need . . .
07-31-22 11:17 AM - Post#2845221
im sorry that none of us has been able to help you on this. you may want to post in the fuel injection or performance sections. welcome to ct. i will take a blind swing at it. reverse and neutral switches could posibly be in or on the trans itself? dodono if this helps. https://paceperformance.com/files/Customer%20Down l...
Edited by bobb on 07-31-22 11:20 AM. Reason for edit: No reason given.
Execution time: 0.236 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:33 PM
