Username Post: 3rd Brake Light        (Topic#368906)
Junk86
Reg: 03-15-19
07-09-22 04:59 PM - Post#2844091
My 3rd brake light will not work. I've checked everything the service manual tells you to check. But have had hardly any luck keeping the light working. One time it works and shortly thereafter it quits again. I have even attached extra ground wires to both terminals from the window bracket bolts, but it still will not work. I have power to the blue wire at the rear connector, but no power @ the light on the glass. Need some help, getting it to stay working. 1986 Camaro
Edited by Junk86 on 07-09-22 05:00 PM. Reason for edit: No reason given.
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
07-10-22 06:42 AM - Post#2844121
    In response to Junk86
Check the bulb fitment and the condition of the bulb ends. Over time they can flatten out and also the plastic that holds the metal tabs in place degrades.
paulo57509
Loc: CA
Reg: 07-18-00
07-13-22 08:26 PM - Post#2844338
I didn't know how the '86 is wired. It's wired thru the hatch contact like the '87- ?
This link may help you.
https://www.thirdgen.org/forums/electronics/68 5360...
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
Edited by paulo57509 on 07-13-22 08:28 PM. Reason for edit: No reason given.
Execution time: 5.135 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:45 PM
