rn59sedan
Reg: 06-27-22
06-27-22 08:09 AM - Post#2843432
Greetings! Asking this for a friend, literally. He has a C4 with around 60K miles with the manual transmission. It has been in storage for the winter, and on the 1st drive, moving the shifter between gears is hard, and the clutch depress seems to have no tension. Release of clutch seems good. Wondering if there are any know issues with the C4 Manual transmission after storage time? I can get more details or description if needed. Thanks!
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
06-27-22 01:52 PM - Post#2843452
In response to rn59sedan
Sounds like the hydraulic clutch actuation and the system might need a new cylinder.
Try this
https://www.corvetteforum.com/forums/c4-tech-perfo...
People fear change because it threatens what they know, or what they claim to know. |
rn59sedan
Reg: 06-27-22
06-27-22 02:13 PM - Post#2843455
In response to Tony1963
Thanks for the reply! I will pass it on to my C4 owner!
rn59sedan
Reg: 06-27-22
06-27-22 02:53 PM - Post#2843459
Forgot to note the Year: It is a 1994, if that makes a difference.
Mel Foye
Reg: 09-29-00
06-28-22 10:15 AM - Post#2843502
Does it get freer the more he drives? Way to heavier lube?
It Was On Fire When I Laid Down. |
TAT_2
Site Ambassador - Member #26 - "21st Year" Silver Supporting Member
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
06-28-22 03:58 PM - Post#2843520
The C4 clutch hydraulic system is both self-bleeding and non-adjustable. Cycling the clutch pedal multiple times while on a level grade before driving will displace any trapped air pockets formed within either cylinder. If the threaded fittings of the hydraulic line between the clutch master and slave cylinder are tight there are only three places where air can enter into the slave cylinder assembly: The slave cylinder seal, the master cylinder seal or the fluid reservoir inlet.
I HAD A LITTLE FREE PLAY WHEN I BOUGHT MY 93,I JUST KEPT PUSHING THE PEDAL IN & OUT TILL IT WENT AWAY.BTW,I DRIVE MY 93 YEAR ROUND SO IT DOESNT SIT,IMHO NOT DRIVEING THEM IS NOT A GOOD IDEA.
09 PONTIAC- VIBE
08 PONTIAC- G6
93 VETTE - 40TH ANNIV- RUBY RED- LT1/6-SPD/RAG TOP
QUOTE FROM HELEN
