Maxine
Reg: 03-05-13
06-23-22 11:26 AM - Post#2843268
I have read more than a few threads on rebuilding this tranny and watched several videos, all were very helpful on the things that they discussed. I have not yet seen anything on the removal of the rear bearing support. I have removed the retaining plug and the diagram in the manual appears to have the support pulled out from the back, but so far the puller that I cobbled using bolts to pull it out are not having any effect. I don't think I am near the breaking point, but I don't want to keep applying torque to it if it's never going to come out that way. Any advice?
Member #189 Moderator and "20th Year" Platinum Supporting Member
06-23-22 07:36 PM - Post#2843280
In response to Maxine
Did you look at this sticky by rrauch?
29-41, 42-48, 49-54 Moderator
2019 Ford Ranger Lariat Super Crewcab |
06-24-22 06:01 AM - Post#2843293
If I recall correctly the rear bearing is held in place by a locking ring that will need to be removed first. Can you post a picture?
Maxine
Reg: 03-05-13
06-29-22 12:27 PM - Post#2843580
Sorry for the late reply, by the time I got myself set up for posting pictures, I got the support bearing out and back in, it did in fact get pulled out from the back.
