JLlamas
Reg: 10-17-18
06-16-22 07:30 AM - Post#2842971
Hello all,
I would like to rewire my 1962 Impala 409 prior having my interior installed, prefer to rewire entire car. Any suggestions? Where to buy, suggested brand, etc. I'm open for suggestions or recommendations. Thank you all in advance.
Jimmy
dgstarr
Loc: Portland, OR
Reg: 04-16-13
06-16-22 07:52 AM - Post#2842973
In response to JLlamas
I have found American Autowire to be an excellant source.
dcairns
Loc: Orange CA
Reg: 11-07-03
06-16-22 08:01 AM - Post#2842974
In response to dgstarr
American Autowire
They have great service is you have questions.
- Dave
1964 Impala 4-door sedan
JLlamas
Reg: 10-17-18
06-16-22 08:32 AM - Post#2842976
Thank you for the suggestion!
dgstarr
Loc: Portland, OR
Reg: 04-16-13
06-16-22 10:24 AM - Post#2842979
I have noticed that the 1962 assembly manual shows a one piece Sun tachometer and wiring diagram. All of the factory tach 62's I have seen have been two piece with different wiring. Perhaps the one piece tach was a late in the year change. Does anyone know if this is true?
kingkreeton
Loc: Nashville TN
Reg: 04-15-11
06-16-22 10:56 AM - Post#2842984
As the others have said, AAW is the best and their tech support is awesome. I redid my entire car using their factory fit series. They sell the engine and front light harnesses modified to accept an alternator and HEI distributor. The dash harness is the most pain but it wasn’t too terrible. It helps if you remove the front seats, drop the steering column and remove the instrument cluster.
If doing the dash harness (most important in my opinion) then it is also a good time to replace your firewall insulation pad. That job is not fun either as removing it resulted in it breaking apart in small chunks. I’m pretty sure I’m still blowing that old insulation pad stuff out of my nose.
Shane
64 Impala SS:
Chevy Performance 350HO
4 Speed Muncie
Edited by kingkreeton on 06-16-22 10:59 AM. Reason for edit: No reason given.
Joeyd59
Loc: New Jersey
Reg: 02-11-12
06-16-22 11:26 AM - Post#2842985
American Autowire.They're the ONLY ones I use in my shop and on my 59's.Don Bock is to go to guy!YO!!!
55Brodie
Loc: Little River, SC
Reg: 12-26-15
06-16-22 01:44 PM - Post#2842992
I don't think the Sun non-transmitter FC tachometer models appeared until very late 1962. Certainly after Chevrolet 1962 model year production ceased.
JLlamas
Reg: 10-17-18
06-17-22 07:44 AM - Post#2843025
In response to kingkreeton
Thank you for the suggestion. Seems like this is the recommended brand.
JLlamas
Reg: 10-17-18
06-17-22 07:44 AM - Post#2843026
In response to Joeyd59
Thank you Joeyd59.
BigDogSS
Loc: SoCal
Reg: 12-21-01
06-17-22 09:39 AM - Post#2843034
We are assuming you want exact factory replacement wiring harnesses, correct? As opposed to a generic "hot rod" kit.
Going with factory replacement will be more expensive, but worth the extra money.
Yes, AAW is the way to go.
1967 Chevrolet Impala SS convertible 327 - Ermine White C1 - VCCA Senior Award
1967 Chevrolet Impala SS Sport Coupe 396 - Marina Blue FF - personal "barn-find" lol
Edited by BigDogSS on 06-17-22 09:43 AM. Reason for edit: No reason given.
JLlamas
Reg: 10-17-18
06-21-22 06:16 AM - Post#2843176
In response to BigDogSS
Thank you BigDogSS. I'm going with AAW. I called and reached out and received a breakdown of section, now time to buy.
327
Loc: Ontario , Canada
Reg: 02-09-21
06-21-22 06:17 AM - Post#2843177
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
06-21-22 10:24 AM - Post#2843184
Do not buy the classic update kit, buy only the original wiring harnesses.
The classic update requires at least 50 splices and your firewall has to be cut to mount new fuse box.
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
https://paulstensland.com
