MYFIRST64
Loc: New York
Reg: 12-21-08
06-15-22 09:51 AM - Post#2842938
Finally got around to removing 64 Impala clock, which stopped ticking. Cleaned points and before I re-install, how can I bench test it?
junky
Loc: Northeast CT
Reg: 06-27-10
06-15-22 12:27 PM - Post#2842945
In response to MYFIRST64
ground the case and put 12 volts to the connector on the back of the clock. Best to do this with a fully charged 12-volt battery to simulate actual conditions in a car. If it keeps time for a minimum of 72 hours, then put it back into the car. I did this with my 1962 clock and it lasted about 3 weeks before it stopped working again. Used clocks are always a gamble if they will work for a day or a year.
Impala_Mike
Loc: Emmetsburg, Ia
Reg: 12-15-01
06-15-22 04:59 PM - Post#2842951
Have you given any thoughts to an OER Quartz clock?
They are a bit spendy, 210 dollars, but the reliability is night and day to the original. They look exactly like the original.
I considered this for my impala, but it has factory air, and the dash is a PITA to remove.
Just an idea.
1964 Impala Convertible 327/250 Goldwood Yellow AT,PS,PB,AC,Tilt,AM/FM,Power Seats. |
MYFIRST64
Loc: New York
Reg: 12-21-08
06-15-22 09:11 PM - Post#2842958
In response to junky
Thanks for advice. I will test it using your method.
MYFIRST64
Loc: New York
Reg: 12-21-08
06-15-22 09:13 PM - Post#2842959
In response to Impala_Mike
Have factory air too and it's a PITA. And want to stick with original clock, but Quartz clock look cool too.
junky
Loc: Northeast CT
Reg: 06-27-10
06-15-22 09:38 PM - Post#2842960
I was reading reviews on eBay about the OER clock, and one person claimed that the clock's face wasn't like the original. I haven't seen one in person so I have no way of telling. Like the others that have posted, mine is an air car, and I don't have enough patience left to drop the steering column and pull the dash to replace the clock. Mine tells the correct time twice a day.
ampico-kid
Reg: 07-12-17
06-17-22 06:30 AM - Post#2843021
I had a similar experience when I redid the interior of my 63 Impala (with factory air). I repaired the original clock and it worked (although wasn't real accurate) for about a year and a half, and then it stopped. I bit the bullet and removed the dash to get it out and put in a quartz rebuild kit that uses the original clock housing, face, and hands, so it looks 100% original. Keeps perfect time now and look totally authentic. Pricing for the kit is not cheap, but not all that bad considering what they want for a total repro quartz clock replacement. Here's the Ebay link:
https://www.ebay.com/itm/255454702690?hash =item3b7...
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
06-17-22 11:07 AM - Post#2843040
In response to ampico-kid
Was it very hard to install the conversion , I had mine working for about a week then nothing.
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327 |
ampico-kid
Reg: 07-12-17
06-17-22 12:16 PM - Post#2843047
In response to 69_BOWTIE
Not difficult at all. Plus they give you a link to a YouTube video that goes over the whole process. Just a few simple gears to replace, and it fits right into the original casing. Looks great and works perfectly.
junky
Loc: Northeast CT
Reg: 06-27-10
06-17-22 09:49 PM - Post#2843064
Might you be able to provide the link?
ampico-kid
Reg: 07-12-17
06-18-22 07:35 AM - Post#2843074
Here's the link, and a scan of the instruction sheet that comes with the new Quartz clock mechanism.
https://www.youtube.com/watch?v=tWj1hvlQ8lg
e85 near me now
