Username Post: Tires for my 1948 Fleetline Aerosedan        (Topic#368692)
jonnyzepp
Loc: Rochester, NY
Reg: 03-24-15
06-13-22 04:07 PM - Post#2842873
I have 600-16 bias-ply tires on my 1948 Fleetline Aerosedan. They came with it when I bought it. They are old and need to be replaced. I was thinking of going to a radial of the same size from Diamond Back. Will I need tubes? I think my current tires have tubes.
Does anyone have an opinion of the Diamond Back radials? I hate the bias-ply ride.
Thank you.
Edited by jonnyzepp on 06-13-22 04:08 PM. Reason for edit: No reason given.
Member #189 Moderator and "20th Year" Platinum Supporting Member
06-14-22 05:47 PM - Post#2842925
    In response to jonnyzepp
I put radials on my 48. About 10 years ago. Did not use any tubes and they have never went down. Do add a little air once in a while. Do not know about the Diamond Backs.
29-41, 42-48, 49-54 Moderator
pauldian
pauldian
Loc: seligman,arizona
Reg: 05-14-09
06-14-22 08:10 PM - Post#2842933
If the rims on your car are in good shape and not bent in any way you should be Ok. As for diamond back tires I've not heard anything negative about them.
They've been around for a long time.
Remember,I'm not always right. But I'M never WRONG !
lofat46
lofat46
Loc: Bloomingdale, IL
Reg: 08-12-13
06-15-22 08:33 PM - Post#2842957
My second set of Diamond Backs are being delivered tomorrow 6/16. Love them. DB also has a radial that looks like a bias ply tire if you want the original look. Mine are wide white radials. Go to dbtires.com, fill in the required info as wheel diameter and tire size you’re looking for and it will give you the price.
Edited by lofat46 on 06-15-22 08:35 PM. Reason for edit: No reason given.
Execution time: 0.138 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:56 AM
