Username Post: Head bolt removal        (Topic#368671)
Dans55
Reg: 03-03-22
06-12-22 11:41 AM - Post#2842771
I need to remove the heads on a generation 1 350. Is there a sequence for removal?
Keeper
Reg: 06-12-22
06-12-22 12:42 PM - Post#2842779
    In response to Dans55
I always went clockwise outside to inside.
Though I am not sure there is a sequence for removal.
Keep
sz0k30
sz0k30
Loc: Oakland Co., Michigan
Reg: 10-12-08
06-12-22 01:38 PM - Post#2842781
    In response to Keeper
There is a sequence for installation tightening. as far as taking them off, whatever you feel like.
Site Ambassador
06-12-22 01:49 PM - Post#2842782
    In response to sz0k30
The sequence for installation is to make sure there is equal clamping forces to ensure a good seal around each cylinder. So there is no specific sequence for removal.
1957 Cameo Carrier
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
06-12-22 03:41 PM - Post#2842792
Reverse order to torque. You want to make sure that you are not loading the force on a single bolt.
Loosen each 1/4 turn, then another 1/4, etc. then when the clamping force is relieved, just pull them all out.
Mel Foye
Mel Foye
Reg: 09-29-00
06-12-22 04:15 PM - Post#2842795
    In response to Tony1963
So you were paid by the hour?
It Was On Fire When I Laid Down.
Tony1963
Reg: 07-09-18
06-13-22 01:22 AM - Post#2842806
    In response to Mel Foye
If you cannot make a meaningful post to assist the original poster with the question, please refrain from your comments.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
06-13-22 05:08 AM - Post#2842818
Mel,
If 'tony1963'/Mercedes/'Tony 1963' would follow the guidelines he posted in response to your post, he would have NOTHING to say.
Virtually ALL his comments are useless information at best. Too many are simply inaccurate/BS. Been going on since about 2009.
What an ignorant stooge.
Pete
06-13-22 06:58 AM - Post#2842827
i never have. installation must use the pattern and more important, use 3 stages. need to check the head bolts to be sure where the head of the bolt seats there is enough meat to seat on to. you may need new head bolts with bigger contact area.
Mel Foye
Mel Foye
Reg: 09-29-00
06-13-22 07:28 AM - Post#2842830
Well Tony1963 you are suggesting more meaningful replies on my part. You maybe correct and since the op may not have much engine tear down experience and his question had already been answered I could have taken a different path.
I could have stated most heads are held down by bolts but sometimes studs and nuts are used.
And sometimes you find their nuts are tighten down way too tight. Melvin the Meaningful.
Edited by Mel Foye on 06-13-22 08:17 AM. Reason for edit: No reason given.
sz0k30
sz0k30
Reg: 10-12-08
06-13-22 11:56 AM - Post#2842861
Seems like the only meaningless post here was yours.
Tony1963
Reg: 07-09-18
06-13-22 12:19 PM - Post#2842864
With 17 head bolts on each side, turning each 1/4 turn until the clamping force is removed would likely take 3 or 4 passes around. If you consider 6 seconds for each bolt's 1/4 turn, that's a total of not more than 7 minutes per side to remove the clamping force. Then remove the bolts.
So, for both sides, we are talking a procedure that calls for 14 minutes in total. Call it 20 minutes if you like.
And I am being asked about being paid by the hour?
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
06-13-22 03:27 PM - Post#2842874
once again, mission accomplished
VC56S 2 door Sedan, 42 Years
06-13-22 08:26 PM - Post#2842885
    In response to Bad56Sedan
NOW NOW CHILDREN.
cant we all play nicely?
tony, go to your room
lol.
ok, now you can shoot me. lol
Mel Foye
Mel Foye
Reg: 09-29-00
06-14-22 09:03 AM - Post#2842906
    In response to bobb
Well bobb you should know that the peacemakers are the first ones shot! :laugh :
Execution time: 0.108 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:03 PM
