Username Post: changing from standard bulb to led        (Topic#368670)
likearock68
Loc: PA
Reg: 03-26-22
06-12-22 11:42 AM - Post#2842768
I recently changed out the old incandescent lighting in my 68 c-10 dash to LED's but now I have no light for the dash only the directional and headlights work. I've checked and rechecked all the wiring and connections nothing appears to be wrong any suggestions?
06-12-22 12:25 PM - Post#2842770
    In response to likearock68
led lights are polarized. do you have power and ground to them?
likearock68
Loc: PA
Reg: 03-26-22
06-12-22 01:31 PM - Post#2842777
    In response to bobb
The dash is plugged in with the wire harness, it was all working before. I probably need to check that wiring. I purchased the truck back in 2019, and whoever owned it before I guess they did the best they did but it looks like they just put band aids everywhere to sell it. So some of the wiring doesn't match up to the 67-72 diagrams like green wire from ign sw to dash wire harness doesn't exist. But it did work before so I'm kinda stuck
06-13-22 07:54 AM - Post#2842826
check fuses. bypass dimmer
doubleE
Loc: Eagan MN
Reg: 06-02-03
06-13-22 10:27 AM - Post#2842841
    In response to bobb
Just wondering, LED lamps, unlike incandescent bulbs, need a certain voltage to work. If the built-in rheostat dimmer (which you operate by turning the light switch clockwise to increase brightness) is not set high enough the voltage may not be enough to fire the LEDs. If you turn it to max and still no lights, measure the voltage output to the panel lights.
Eric
likearock68
Loc: PA
Reg: 03-26-22
06-13-22 02:55 PM - Post#2842868
    In response to bobb
thx I'll give that a try
likearock68
Loc: PA
Reg: 03-26-22
06-13-22 02:56 PM - Post#2842869
    In response to doubleE
sounds good I'll give it a try thx
Execution time: 0.199 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:32 PM
