Username Post: 48 Fleetline steering gearbox        (Topic#368663)
STOKER1948chevy
Loc: OHIO
Reg: 08-03-21
06-12-22 02:43 AM - Post#2842733
anyone know the ins and outs of removing the steering gearbox. Any tips would be appreciated.
Broo102
Broo102
Loc: Huntington Beach, CA.
Reg: 09-30-14
06-13-22 11:57 AM - Post#2842852
    In response to STOKER1948chevy
Its not a huge project. Access is the main pain, but removing the wheel well skirt sheet metal makes it easier.
once thats done, under the car work is necessary.
unbolt the pittman arm and use a puller to detach it first.
The shaft is held by a bolt after you unbolt or at least loosen the box from the frame first.
The box should readily pull away from the shaft, it will fall down, its heavy, so be prepared.
The old Chevy manual is a good place to start, its free to download
Hope that helps
Bru
Thanks!
Bru
John 3:16
32 Chev. 5 Win. Sports Coupe
STOKER1948chevy
Loc: OHIO
Reg: 08-03-21
07-06-22 05:48 AM - Post#2843945
    In response to Broo102
Thanks for the helpful info. I got it done before reading your post. It was not as bad a job as I expected, but it was a job. I was glad to get it down on the bench. Take care. And thanks again.
Execution time: 0.137 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:25 PM
