Username Post: 1972 Nova Fuel Problem        (Topic#368648)
HandyAndy
Loc: Iowa City, IA
Reg: 09-05-19
06-09-22 06:04 PM - Post#2842629
Same car, 1972 Nova with a 454 four barrel carburetor. The engine will run for 20 or 30 minutes and then quit. A see through fuel filter is bone dry. After the car sits for a while, there's fuel visible in the filter and the engine will re-start. I thought I solved this by venting his 'vented' fuel cap, but the condition continues. Could a fuel pump act like that? Could there be debris in the fuel tank that creates an obstruction? An internal carburetor problem? We're running out of ideas, so I thought I'd run this by you for some troubleshooting directions.
Thanks!
HandyAndy
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
06-11-22 10:52 AM - Post#2842711
    In response to HandyAndy
No fuel in the filter sounds like an obstruction to me. You'll have to figure out if the obstruction is in the tank or the lines.
Use a hand held vacuum pump to see if you can draw fuel through the line and if not, see if you can pull it out of the tank.
Site Ambassador
06-11-22 11:29 AM - Post#2842713
    In response to Tony1963
Sounds like the pickup in the tank is getting blocked. If there is debris in the tank it will float on the gas and the pump creates suction while drawing fuel. Eventually the debris gets sucked into the pickup, which usually has a sock on it to prevent dirt from getting to the engine. Kind of a pre-filter. When the sock gets clogged, the engine stalls and no fuel comes through the line. Once the suction stops the debris will come off the sock and let fuel through again. If it was the in line filter it likely would not be dry when this happens. When it happens, disconnect the line from the tank and run a short line to a can of gas and see if the pump draws as it should. Mechanical pumps don’t draw too well, so having the can higher than the pump and the line primed would help. Be very careful and have a fire extinguisher handy. Things don’t usually go wrong when running the car from a gas can. But fires can happen and you want to be ready if it does.
1957 Cameo Carrier
HandyAndy
Loc: Iowa City, IA
Reg: 09-05-19
06-13-22 02:45 PM - Post#2842866
    In response to wagonman100
Thanks for your replies! We will try your suggestions. I'll circle back and let you know how we did.
Thanks again,
HandyAndy
HandyAndy
Loc: Iowa City, IA
Reg: 09-05-19
06-26-22 06:38 PM - Post#2843416
We dropped the tank and it was absolutely clean. No problem with the pick-up tube or sock. The fuel line was unobstructed from the tank to the fuel pump. The fuel pump failed a vacuum test.
The new fuel pump solved the problem. Thanks for your help fellas!
HandyAndy
Execution time: 0.109 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:26 AM
