Username Post: 1972 Nova Turn Signals        (Topic#368647)
HandyAndy
Loc: Iowa City, IA
Reg: 09-05-19
06-09-22 04:59 PM - Post#2842626
My buddy has a 1972 Nova and the turn signals don't work. Interestingly enough, the four-way flashers work?
I assume the light sockets and grounds are good. Could it be a flasher or the turn signal switch? If I'm not mistaken, the turn signals and four-way flashers have separate flashers.
Any troubleshooting suggestions would be appreciated.
HandyAndy
HandyAndy
Loc: Iowa City, IA
Reg: 09-05-19
08-20-22 05:36 PM - Post#2846197
    In response to HandyAndy
Update: We finally spent some time chasing the turn signal issue around. The main gauge cluster connector was corroded. We cleaned that and the fuel gauge began to work! I noticed the main fuse block is also quite corroded. Can someone explain how the fuse block is wired? It looks like there are two circuits to a fuse (see LINK 1973 Nova Fuse Block -example). Initially, I checked for continuity on the fuses; however, it appears the clamps for the fuses are corroded and likely the problem. It seems to me that even if the fuse is good and power is available, for example the DIR. SIG. and BACK UP circuit, and the fuse clamp is corroded power may not be available to a given circuit. I ended up wiring an ignition wire to the turn signal flasher and the signals seem to work fine. For some reason, 12V power is not making it to the flasher: bad connection, broken wire, something else?
HandyAndy
HandyAndy
Loc: Iowa City, IA
Reg: 09-05-19
09-09-22 08:59 AM - Post#2847073
Here's a couple pics from a donor fuse block. Maybe they will help someone else out......
GM Fuse Block
HandyAndy
HandyAndy
Loc: Iowa City, IA
Reg: 09-05-19
09-23-22 09:17 AM - Post#2847697
We finally got some positive results with the electrical problems. The connector on the back of the gauge cluster was disconnected and cleaned. Also, the fuses were removed and the fuse clamps were cleaned up with a Dremel tool. The turn signals are now working through the stock wiring harness.
All the circuits on the fuse block have continuity from fuse clamp to fuse clamp with a fuse in place, with one exception: the INST LPS 4A. There isn't any power to that circuit. A green wire runs to the headlight switch and a gray wire runs to the printed circuit board connector, both wires originate at the fuse block. In fact, with the headlights on and the headlight switch turned to the left for a dome/courtesy light the green turn signals are dimly lit? The turn signals work just fine regardless of the headlight switch position.
I'm wondering if there's still a problem with the printed circuit board on the back of the gauge cluster?
HandyAndy
Loc: Georgetown, Texas
09-23-22 10:52 AM - Post#2847702
Thanks for keeping us updated Andy!
Execution time: 0.111 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:53 AM
