rod
Member #248 Senior Member
Loc: kingman,az
Reg: 04-29-00
05-31-22 06:41 PM - Post#2842107
`my neighbor has a Camaro rear axle, complete, under his 55 Chevy tk. it is a 10 bolt, and from an unknown year Camaro
what gear ratio is this?
2-PE-G82832 date code J87
thanks Rod in AZ
grumpyvette
Loc: farmersville texas USA
Reg: 03-16-01
06-04-22 12:22 PM - Post#2842299
In response to rod
https://www.novaresource.org/axle.htm
IF YOU CAN , YOU NEED BETTER TIRES AND YOUR SUSPENSION NEEDS MORE WORK!! |
Edited by grumpyvette on 06-04-22 12:24 PM. Reason for edit: No reason given.
rod
Loc: kingman,az
Reg: 04-29-00
06-06-22 03:27 PM - Post#2842473
In response to grumpyvette
thanks Grumpy
Rod in AZ
