Username Post: c-10C-20 to C-10 front end conversion        (Topic#368548)
shortstepside67
Loc: MA
Reg: 05-30-22
05-30-22 07:48 AM - Post#2842023
I have a 67' c-20 that im converting to disc breaks, im using the original cradle with the 5/8" studs for the upper control arm. i think the upper a- arm shaft assembly will fit the upper control arm in 1/2 ton or 3/4 ton the only change seems to be the ball joint, can the lower ball joint in 1/2 ton be installed in the 3/4 ton control arm? i have a complete 72' c-10 cradle with disc brakes that im stealing parts from. wondering if i need to use the 3/4 ton lower control arm. Any help would be very appreciated.
Execution time: 0.112 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:29 PM
