Deuce_Coupe
Loc: Mankato, MN
Reg: 09-18-01
05-23-22 04:02 PM - Post#2841694
Two questions.
#1 Can the "lock ring" on the backside of the bearing be reused? I thought I read someplace that they should be replaced when replacing the bearings.
#2 Does it matter which way the bearings are installed? Right now the O-ring is on the outside and I'm wondering if I can put the O-ring to the inside. The housing has a better surface on the inside for the O-ring.
Sealed bearings 1956 Chevy.
32 5W Coupe
53 Bel-Air 2dr sedan
64 Chevelle Convert
65 Impala 2dr HT
78,87 Silverado K20
86,87,90,91 Suburbans |
