Username Post: Correct top hose for Aluminum rad on 59        (Topic#368410)
tikiwagon
tikiwagon
Loc: dorset, england
Reg: 04-23-04
05-12-22 12:33 PM - Post#2841107
Hi I have just fitted my Notched Radiator in my 59 for use with a 500 series box, I have got the bottom hose fitted with a bit of cutting down but it is very near to the fuel pump outlet but the top hose that i have(Gates Part # 23080) is too short as i can see that the top hose outlet is further over to the left compared to a stock rad, does anyone know what the right part #is or what will work, It is the right shape but about 2-3" too short, Thanks
https://www.facebook.com/messenger_media/?thre ad_i...
Edited by tikiwagon on 05-12-22 12:40 PM. Reason for edit: No reason given.
Member #189 Moderator and "20th Year" Platinum Supporting Member
05-15-22 04:38 PM - Post#2841236
    In response to tikiwagon
Take your old hose to an auto parts store. They normally have a bunch of hosed hanging on a wall. You should be able to find one that will fit.
29-41, 42-48, 49-54 Moderator
tikiwagon
tikiwagon
Reg: 04-23-04
05-16-22 12:32 PM - Post#2841287
I would do that but i am in the UK and not very likely to find a hose like that on the shelf over here
05-17-22 08:28 PM - Post#2841388
oops. I should have read your info. I am at a lose for the UK.
tikiwagon
tikiwagon
Reg: 04-23-04
05-17-22 11:17 PM - Post#2841393
Thanks for the answer anyway
Execution time: 0.218 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:22 PM
