badbob85037
Loc: Arizona
Reg: 03-13-09
05-12-22 12:18 PM - Post#2841105
I will make this post short and to the point. A year and a half ago I bought a rebuilt 350 Chevy long block from O'Reilly Auto fom my 1974 K-10. It lasted 2 months before it failed. After a couple of phone calls with Gearhead Engines out of Texas it didn't take long to realize I was dealing with liars and cheats. The second engine was never drove out of the drive way. Valves were sticking and the rings were put in up side down and in the wrong groves. O'Reilly was no help getting a third engine. I started filing a law suit. Before I filed it my wife call the national office. She told them about the first two engines and the law suit I was filing and I would not except another engine from Gearhead. They told her they didn't buy engines from Gearhead because of their lack of any type of quility. After finding out the manager did get the engine from gearhead I was given a third engine and was told it was not from Gearhead. These first 2 engines had their VIN numbers removed and MEXICO stamped where the VIN numbers had been. The third engine had also had the VIN numbers removed with MEXICO stamped where the VIN numbers had been. Like an idiot I installed it. This engine won't start because the intake valves are not closing and all it does is backfire out the carb. That is where I'm at. This morning I will run a compression test then lawyer up and get back what I payed including the jobs I lost for the down time on the truck and a year and a half of my labor or go postal.
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
05-12-22 01:06 PM - Post#2841110
In response to badbob85037
You will have to prove your case. Saying that the engine was assembled wrong and proving it are not the same.
You need to have some type of evidence to support your claims.
You also had some type of warranty and limitations that you agreed to when you purchased the engine. All warranties that I have read exclude any consequential damages. That means that you cannot collect from other things that go wrong as a result of the product failing.
By the time that you pay a lawyer, you will have in excess of the cost of an engine from the GM dealer many times over. However, do as you see fit.
If you buy an engine from the retail store, you cannot dictate to them where the engine comes from since that is not your contractual right.
05-12-22 01:40 PM - Post#2841112
In response to Tony1963
Plus you would need an expert witness in court to back up your claim, more money. A complaint with the states consumer affairs may help, or states AG office.
badbob85037
Loc: Arizona
Reg: 03-13-09
05-12-22 08:16 PM - Post#2841122
Before they gave me the engine I had dotted the eyes and crossed the t's in a small claims court. I have documented every thing since discovering what a bunch of cornholes they were on the first replacements. If it is an issue any issue I have a lawyer this time and I'll be asking for a lot more than another piece of Cr%& engine, lost wages, my time spent changing them out, lawyer's fees, even because of what a nice guy I have been letting them get away with this assault on good nature. I am beyond mad.
Tony1963
Reg: 07-09-18
05-13-22 02:31 AM - Post#2841127
You can hire all of the lawyers in the country, but that will not change the law. If the original contract excludes consequential damages, you will collect nothing.
The lawyer will gladly take your money.
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
05-13-22 07:58 AM - Post#2841136
Info----A very influential (unnamed) Owner of a Shingle Co. in JOPLIN MO, traveling, multiple times, to Washington, several years ago, lobbied, at great expense, and got a law passed.
If you are going to sue a company, you are going to have to go to court in their home state, not the State where they did the business, but the State, where they have already, bought, and paid for, powerful friends.
DISCLAIMER-THIS WAS IN NO WAY A POLITICAL POST
1952 Styleline Sedan, 62-235, Drum brakes, Manual steering, 2" Drop, 8-60 AC, Glass packs, Two Carbs, and a Cast Iron PowerGlide-
Way out behind the Old School
Half a Dozen in a Row, all it needs for Her to go.
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
05-13-22 08:11 AM - Post#2841137
In response to gcrkfrd
I have a Small Block Chevy Water Pump, in my Garage, that I bought from them several years ago. All of the bolt holes are 5/16"-
Another O Orealy Riddle
kingkreeton
Loc: Nashville TN
Reg: 04-15-11
05-13-22 09:06 AM - Post#2841141
If you paid for it with a credit card, maybe file a claim with your CC company.
Shane
64 Impala SS:
Chevy Performance 350HO
4 Speed Muncie
05-13-22 09:49 AM - Post#2841142
Small claims in N.Y. requires filing in the jurisdiction where they do business or have an office, if they are out of state then you are stuck.
1965C-10
Loc: San Tan Valley AZ "Phoeni...
Reg: 11-18-01
05-13-22 01:58 PM - Post#2841159
I wonder if this is the same company called ATK from Texas, also another name that sounds like Marlboro cigarettes, can’t remember exactly.
Sorry to hear you got ripped off, hope you can get your $$ back and buy a new 350 long block from GM, probably made in Mexico.
Where is your original 350?
Edit Mabbco engine may be the same company.
Edited by 1965C-10 on 05-13-22 02:01 PM. Reason for edit: No reason given.
Tony1963
Reg: 07-09-18
05-13-22 03:25 PM - Post#2841162
In response to 1965C-10
Another problem that you are facing is that the engine design from 1974 ended in 1986 (Gen I engines before major changes). So, at this point, any engine in that era is AT LEAST 36 years old. Yes, you can use a newer design, but consider how many times those engines have been apart, etc.
I would always rebuild what I had unless it was beyond repair.
Senior Moderator
05-14-22 10:51 AM - Post#2841197
It's a little hard to follow but it sounds like O'Reilly corporate told you that they don't source engines from Gearhead, but maybe your local store did? It may help you (LONG SHOT) if you can find out if they have a specified vendor for engines or if the local store manager has flexibility in this regard. If he went outside of official vendors you MIGHT (BIG MIGHT) have some recourse. As the others have said though, it's going to be an uphill battle.
06 Silverado ISS / 06 Silverado SS / 06 300C SRT8 |
Tony1963
Reg: 07-09-18
05-14-22 12:12 PM - Post#2841200
In response to someotherguy
I am certain that this auto parts chain has been sued so many times it is beyond count. Filing the lawsuit will barely invoke a yawn from their corporate office. They've had lawyers working for them since they were first organized as a business.
Your purchase contract covers the terms of the transaction. Any judge or lawyer cannot invent new terms.
I'd love to have a front row seat to this case, just to watch the fireworks.
05-15-22 12:34 PM - Post#2841226
sounds like an atk nightmare. 1st one i put in, couldnt bolt a starter to. 2nd one had a rod knock on start up. 3rd one blew up in less than 500 miles. i feel your pain.
carbking
Loc: Missouri
Reg: 06-14-03
05-16-22 09:53 AM - Post#2841280
In response to bobb
The best recourse I have experienced with issues such as these is to write a NICE letter going through the issues one by one, step by step, to the corporate office, and COPY the Attorney General in your state.
Attach copies of documentation to both corporate and the AG.
NOTHING gets the attention of corporate like an official letter asking for details from the AG.
The key here may be to get someone that is not angry to write the letter for you. A letter that reeks anger will acquire worse results than one that does not.
Good luck.
Jon.
Good carburetion is fuelish hot air!
The most expensive carburetor you will ever buy.....is the incorrect one you attempt to modify!
If you truly believe "one size fits all", trying walking a mile in your spouse's shoes! |
Tony1963
Reg: 07-09-18
05-16-22 03:09 PM - Post#2841300
In response to carbking
There is a legal theory of "impossible" meaning that if best efforts are made to come up with a product and it simply isn't available, the contract can be voided. Of course, you'd get your money back and you'd have to be fairly compensated for your core, assuming that you surrendered one.
05-17-22 03:53 AM - Post#2841323
A friend had a similar issue. It was a F$%D with a 351W vs 351 Cleveland. The wrong one was ordered first since my friend didn't know what was installed. The correct engine had mismatching heads! The third engine finally looked good enough to install. It ran for years before the truck was sold. I would remove parts, covers, and pan to check before installing any over the counter motor. I found my ZZ4 on Craigslist. The intake, valve covers, and pan all came off for inspection. To this day, it runs great and no oil leaks.
'08 GMC Acadia 3.6L SLE
