Username Post: Air cleaner riser        (Topic#368408)
Stickdude
Stickdude
Loc: North Central Wyoming
Reg: 07-29-17
05-12-22 05:51 AM - Post#2841088
Does anyone know of an air cleaner riser for a Rochester B carb? The intake diameter is 2-5/8". My stock air cleaner (if I have the right one) hits the valve cover and intake fuel line. I only need to raise the ac an inch so. I can't find a riser on line.
Attachment: Rochester_B.png (154.57 KB) 23 View(s)
53sd
Reg: 12-08-08
05-12-22 08:34 AM - Post#2841095
    In response to Stickdude
Do you have the insulator/spacer between the intake manifold and the carb?
I would imagine the stock air cleaner wouldn't hit the valve cover.
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
05-12-22 09:10 AM - Post#2841097
    In response to 53sd
Classic Truck Parts Kansas City
Got my carb spacers and intake rings there
1952 Styleline Sedan, 62-235, Drum brakes, Manual steering, 2" Drop, 8-60 AC, Glass packs, Two Carbs, and a Cast Iron PowerGlide-
Way out behind the Old School
Half a Dozen in a Row, all it needs for Her to go.
Edited by gcrkfrd on 05-12-22 09:12 AM. Reason for edit: No reason given.
Stickdude
Stickdude
Reg: 07-29-17
05-12-22 10:21 AM - Post#2841099
    In response to 53sd
No all I have is a paper gasket, thanks.
Stickdude
Stickdude
Reg: 07-29-17
05-12-22 10:51 AM - Post#2841101
    In response to gcrkfrd
No luck there yet.
Stickdude
Stickdude
Reg: 07-29-17
05-12-22 11:37 AM - Post#2841104
I did see one for a 216 and a 235 with some C-C dimension. I'll have to do some measuring to see if they might work on a 292.
pauldian
pauldian
Loc: seligman,arizona
Reg: 05-14-09
05-12-22 12:22 PM - Post#2841106
etor Insulators
Chevrolet Parts - 206 & 216 CID CARBURETOR INSULATOR
FS-106 $12.50 EA
CHEVROLET 206 & 216 CID CARBURETOR INSULATOR
This hard block goes between the carburetor base and the intake manifold as a heat shield. Often times these are cracked and can cause the same symptoms as an intake manifold leak. Check yours anytime you remove the carburetor. Bolt hole centers are 2-3/4. Center hole size is 1-5/8.Overall Height .600"
For sale at www.fillingstation.com or www.chevsofthe40s.com
For 1933 1934 1935 1936 1937 1938 1939 1940 1941 1942 1944 1945 1946 1947 1948 1949 1950 1951 1952 1953 Chevrolet Cars and Trucks
Chevrolet Parts - 235 CID CARBURETOR INSULATOR
FS-238 $12.50 EA
CHEVROLET 235 CID CARBURETOR INSULATOR
Remember,I'm not always right. But I'M never WRONG !
Stickdude
Stickdude
Reg: 07-29-17
05-12-22 12:56 PM - Post#2841109
    In response to pauldian
Thanks, I get a lot more hits when I use insulator instead of spacer (and thanks 53sd).
Stickdude
Stickdude
Reg: 07-29-17
05-12-22 02:16 PM - Post#2841114
So here is where I am at: I'm finding insulators (spacers) close but no cigar. My Rochester B, number 7024009 (verified by tag and stamped number on bottom of base) bottom bore measures 1-3/4", C-C bottom mounting holes measure 1-15/16".
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
05-12-22 03:57 PM - Post#2841115
A couple of things. The carburetor you show is about 1958 (or newer) vintage. They used a different type of air cleaner as opposed to what was used in 1949-54. Second, there are two different insulators. One for the 216 (2-11/16") and one for the 235 (2-15/16". I think that's what you meant as opposed to 1-15/16". You need a 235 insulator.
Chevs of the 40's LINK:
https://www.chevsofthe40s.com/shop/search.lasso?ve...
1951 Fleetline Preservation
Stickdude
Stickdude
Reg: 07-29-17
05-13-22 04:59 AM - Post#2841130
    In response to RAM_51
Yes, I did mean 2-5/16", thank you.
When I went to the Filling Station they listed the 235 insulator as being 3" C-C. Now I see at Chev's of the 40's they show the 235 insulator as 2-15/16" C-C (thanks pauldian).
Here is what I found at the Carburetor Doctor:
Rochester Carburetor Numbering System
By the mid-1960s Rochester carburetor numbers started to become mostly standardized. Here are a couple of Rochester numbers decoded as examples:
7026203
'70': until 1975, all factory production Rochester numbers start with '70'
'2': 1960's carbs generally have a '2' in this place ('3' in this spot means special emissions, eg. California)
'6': means theyear six of the decade (1966).
'203': means Chevy 4 bbl (Quadrajet); '3': means manual transmission. Odd number are usually manual transmissions.
17080212
'170': starting in 1975, most Rochester numbers start this way
'8': means 1980's
'0': 1980
'212': means Chevy 4 bbl (Quadrajet); since this happens to be a truck carburetor, it could be manual or auto trans
That would make my 7024009 carb a 1964, same as my 292 engine.
You are right, I need a 235 insulator, thanks Ram.
Attachment: 20220513_053413A.jpg (218.25 KB) 0 View(s)
Stickdude
Stickdude
Reg: 07-29-17
05-13-22 06:06 AM - Post#2841132
$19.25 for 1 insulator & 2 gaskets (I'm ok with that) but $25.22 to ship Cof40s
pauldian
pauldian
Reg: 05-14-09
05-13-22 06:33 AM - Post#2841133
https://www.ebay.com/itm/173912022412 and get the gaskets from https://www.speedwaymotors.com/Search?query=carbur...
Edited by pauldian on 05-13-22 07:03 AM. Reason for edit: No reason given.
Stickdude
Stickdude
Reg: 07-29-17
05-13-22 07:28 AM - Post#2841135
Thanks, and here's an interesting bit of description form that Speedway link:
2.94" carb bolt center to center, or what is commonly referred to as the ' 3" ' carb or 'big pattern' carb with the 2-15/16" carb bolt spacing
I had found gaskets and insulators on other sites but they either did not list dimensions or listed the 235 stuff C-C as 3" so I was not sure if they would fit. One place even listed the gaskets as fitting both the 216 and 235.
Thanks again Pauldian
805chevy
Loc: Central Coast California
Reg: 08-04-20
05-13-22 10:03 AM - Post#2841145
You might want to try the Truck and Car shop in Orange California. They also have a shop in the east.
http://www.truckandcarshop.com/41-57car/c41_181.ht...
Stickdude
Stickdude
Reg: 07-29-17
05-14-22 04:21 AM - Post#2841184
    In response to 805chevy
Thanks 805, they have a lot of stuff.
Execution time: 0.114 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:27 AM
