Username Post: Faulty Gas Gauge        (Topic#368394)
Custom Sport 64
Reg: 05-01-22
05-10-22 05:08 PM - Post#2840997
Cleaned out the old gas tank & installed a new gas float pick up & made sure the ground was properly afixed w/ dielectric grease. Gauge worked great for a while then needle started going all the way to the right some times then lately it is stuck all the way to the right. Rechecked all of my ground straps - aokay. Someone told me there was some gizzmo on the back of the gas guage that can go faulty?? Any suggestions out there. Thanks
junky
Loc: Northeast CT
Reg: 06-27-10
05-10-22 08:40 PM - Post#2841005
    In response to Custom Sport 64
It isn't in the dash unit, it is located in the sending unit in the tank. Most if not all the reproduction fuel sending units today are pure junk. There are companies that will rebuild your old sending unit to work like new. Hopefully, you didn't toss it when you purchased the reproduction. There are a number of companies around the US that offer this service. Google is your friend to locate them.
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
05-11-22 05:02 AM - Post#2841013
My suggestion is to bench test the sending unit that you purchased. The test involves using a volt/ohm meter and seeing the resistance change as you move the arm.
If you see a steady change in resistance, then you know the unit is working. The rest of the system is simply power and ground.
I'm not a fan of dielectric grease on the ground points as it is non-conductive and can interfere with the ground. You can clean the ground, attach, then spray battery terminal treatment on the ground.
Custom Sport 64
Reg: 05-01-22
05-11-22 09:41 AM - Post#2841034
    In response to junky
Yes I tossed the original unit. Will take the new unit out & test it. Thanks for your input.
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
05-11-22 11:03 AM - Post#2841038
Another problem is that the reproduction floats fail that are on the new senders - they crack and leak filling up with gas making the gauge not read correctly.
I know that a replacement float that fits is a Ford brand float. I remember these new Ford floats were switched( they snap into the holder) by guys replacing their gas tanks with new sending units.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
https://paulstensland.com
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
05-12-22 07:39 AM - Post#2841092
    In response to pvs409
https://www.ebay.com/itm/175255366267?fits =Year%3A...
Execution time: 0.214 seconds.   Total Queries: 20   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:37 AM
