Username Post: 1968 Wagon Gear Indicator Cable        (Topic#368355)
smwalker
Loc: Azusa, CA
Reg: 04-29-22
05-06-22 04:11 PM - Post#2840791
Looking to get my 1968 Wagon back on the road and wanted to get my gear indicator working again. The plastic sheath has totally disintegrated only a cable left.
Found a NOS part for over $200, GM Part Number 6481558 -- don't need it that bad!!
But was wondering any one has ever found a replacement plastic sheath to use to sort of rebuild it? Seems like it might be possible if you can find that thin/small cable holder.
Here is a pic of the NOS one:
https://www.oldsobsolete.com/products-page/chevy-p ...
Steve Walker
PPVSteve@Gmail.com
Azusa, CA
Edited by smwalker on 05-06-22 04:22 PM. Reason for edit: added part number
Jynx
Loc: Australia
Reg: 03-01-11
05-06-22 10:59 PM - Post#2840810
    In response to smwalker
Not sure I fully understand the part you need but if you're referring to the outer cable as the "sheath" then you could buy a universal motorcycle throttle cable & modify it to suit.
Most motorcycle shops that sell the cable should also have an assortment of ferrules etc. Try your local Harley Shop, they might even make it up for you.
67 Impala 4Dr Hardtop.
smwalker
Loc: Azusa, CA
Reg: 04-29-22
05-07-22 12:33 AM - Post#2840812
    In response to Jynx
Thanks Jynx,
Problem is the Cable is so small, and the force needed to move the PRNDL needle is so small I cant upsize anything.
I was able to determine the outer dimention of the sheath is 2.0mm and the cable width is 0.6mm.
Stadard Bicycle cable is about 1.5mm thick.
Think I got a lead in the Hobby world. Think Model Airplanes might use these small cables.
Steve Walker
PPVSteve@Gmail.com
Azusa, CA
Jynx
Loc: Australia
Reg: 03-01-11
05-07-22 01:47 AM - Post#2840815
ok gotcha, it's tiny. I'd guess the i/d of the cable will be 1mm then, so if model planes are no good then google for some tubing in that dimension, it shouldn't be too hard to find.
toro455
toro455
Loc: Western NY
Reg: 06-15-02
05-07-22 12:36 PM - Post#2840837
It looks like maybe something like nylaflow tubing would work as a replacement for the cable guide. Nylaflow is often used for gauge lines and for air shocks. I may be off in the spelling.
Scott
smwalker
Loc: Azusa, CA
Reg: 04-29-22
05-07-22 04:12 PM - Post#2840846
    In response to toro455
Thanks Toro, that looked good but thier smallest is 1/8 of an inch OD or 3.2mm . Cant even believe a GM supplier was even able to make such a small tube 55 years ago! LOL
https://nylaflow.com/sizes/
Steve Walker
PPVSteve@Gmail.com
Azusa, CA
62BillT
"20th Year" Silver Supporting Member
62BillT
Loc: Moneta, VA
Reg: 09-24-01
05-07-22 06:17 PM - Post#2840850
There is a chance that I'll have a good used one. I can check one day next week.
Member:
-National Impala Association
smwalker
Loc: Azusa, CA
Reg: 04-29-22
05-07-22 08:42 PM - Post#2840860
    In response to 62BillT
Thanks Bill
The condition mine was in I will be surprised if any used one has any integrity. I was even concerned with the NOS one sitting in a box for 50 years.
Steve Walker
PPVSteve@Gmail.com
Azusa, CA
Jynx
Loc: Australia
Reg: 03-01-11
05-08-22 01:47 AM - Post#2840863
how about this
smwalker
Loc: Azusa, CA
Reg: 04-29-22
05-08-22 12:11 PM - Post#2840884
    In response to Jynx
OOOH Boy howdy Jynx that looks promising! And cheap to boot!! Thought I was going to be stuck with 1000 feet of the stuff!!
Nice will get some coming my way.
A 3D printer part, who would have thought!
Steve Walker
PPVSteve@Gmail.com
Azusa, CA
smwalker
Loc: Azusa, CA
Reg: 04-29-22
05-11-22 08:27 PM - Post#2841075
Just an update. Asked the guys at Reddit/Photoshophelp to get me length on the tube since mine was non existant.
Got 2 measurements 202 MM and 208 MM So will go with 205mm and see how that works.
Steve Walker
PPVSteve@Gmail.com
Azusa, CA
toro455
toro455
Loc: Western NY
Reg: 06-15-02
05-12-22 06:26 PM - Post#2841119
Steve,
Whenever you need a small amount of something like that check McMaster-Carr. If the 3D printing guide works you won't beat that price though. Nylaflow is used for gauge lines and air shocks so it dates back quite a long time but I'm not certain when it was first used. I don't know what they used before nylaflow... maybe copper gauge tubing? AC TXV's used very small diameter copper tubing going to the sensing bulb.
It will be cool to see how it works for you. If you're not certain of the size you need McMaster-Carr is pretty nice. They seem to charge fair prices and the shipping is typically fair too if you consider several items ship together. For a single item it can be relatively expensive.
Scott
smwalker
Loc: Azusa, CA
Reg: 04-29-22
05-13-22 07:52 PM - Post#2841175
We have success!!!
Tubing and cable came in. Works like a charm. Couple videos of testing. Wanted to make sure the spring on the needle was strong enough to pull it back to the park position. Well strong enough and working well.
Will post another pic once installed in the car.
Thanks for all the leads guys!!
And if anyone ever needs to rebuild one of these I got extra stuff hit me up!!
Cable Testing 1
Cable Testing 2
Steve Walker
PPVSteve@Gmail.com
Azusa, CA
Jynx
Loc: Australia
Reg: 03-01-11
05-14-22 02:00 AM - Post#2841180
Very nice work, good to see it all worked out, sometimes the smallest problems become the biggest challenges, but that makes it so much sweeter when you win.
62sedan
62sedan
Loc: Above the red Texas dirt
Reg: 08-12-02
05-14-22 04:31 AM - Post#2841185
    In response to Jynx
EXCELLENT!!!! Glad you got it working correctly.
Chuck
Execution time: 0.095 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:51 AM
