Username Post: engine turns over hard with advance timing.        (Topic#368345)
jbander
Reg: 07-19-19
05-05-22 10:24 AM - Post#2840741
I've read that you can run a toggle switch to the 12 volt source going into a hei distributor and since it will only turn over without firing it turns over easier and faster , and then you flip the toggle and it starts. Has anyone had any experience with this . It's a 355 with maybe 450 HP.
Is there anyway to adjust timing inside of the car , that doesn't cost a lot of money
05-06-22 10:17 AM - Post#2840781
    In response to jbander
No info here to work with! What is the base timing, what is your compression ratio, are all the cables clean and tite, have you confirmed the starter is in good working condition, does this happen hot or cold?
jbander
Reg: 07-19-19
05-08-22 12:20 PM - Post#2840885
Did you read what I asked about?
05-08-22 01:38 PM - Post#2840893
Yes, of course, it seems like you are describing a hard start or slow cranking condition work around, no? And no, from inside the car you would need a sophisticated timing control module with a matching distributor.
Edited by Shepherd on 05-08-22 01:41 PM. Reason for edit: No reason given.
jbander
Reg: 07-19-19
05-08-22 07:43 PM - Post#2840908
Well then it will be the switch, it has been done many times and I've found help in the wiring .
Execution time: 0.23 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:35 PM
