Username Post: Carter AVS        (Topic#368306)
lobucrod
Loc: Slaton, TX
Reg: 10-01-07
05-01-22 04:06 AM - Post#2840514
I have an original Carter AVS carburetor tag #4028SA. In searching info on this carb I have found that Chevrolet only used this for one year on the 1966 275HP 327. I also have the factory cast iron intake manifold. There is supposed to be a stainless heat shield under the carb like the one used under the quadrajets. Since this is a one year only application apparently the heat shields are hard to come by. Does anyone know where to get one?
'38 Chevy Coupe Gasser 409 powered
'50 Sedan Delivery 401 Nailhead powered
'62 Buick Electra original survivor
elcamino
elcamino
Reg: 03-30-00
05-13-22 04:29 AM - Post#2841129
    In response to lobucrod
AVS?? Do you mean AFB?
My parts book says 327-275 AFB carb (L30) CA emissions (smog motor)
AFB - Aluminum Four Barrel (Carter)
2021 GMC 4WD Sierra Denali CC 6.2L/10-sp
2018 Polaris RZR S 900 EPS
lobucrod
Loc: Slaton, TX
Reg: 10-01-07
05-13-22 05:49 AM - Post#2841131
    In response to elcamino
Chevrolet may refer to all of the Carters as an AFB. The ABS is basically a Carter aluminum four barrel with an air valve over the secondary bores. When doing an internet search for the carb part number most results refer to it as an AVS.
elcamino
elcamino
Reg: 03-30-00
05-14-22 02:36 AM - Post#2841182
Execution time: 0.3 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:08 PM
