Username Post: 60 Corvette puzzling issue        (Topic#368266)
Chevyfellow
Reg: 04-09-22
04-24-22 07:28 PM - Post#2840272
Engine running- I pull out the headlight switch and Amp guage needle goes to deficit. Increasing RPM's does not seem to help. I have had the Generator and Regulator checked out at a shop and they tell me they are fine. After this I tried a new regulator and the problem continues. Battery is new. Bad ground? Something in the headlight switch? :sad :
monty56
monty56
Reg: 04-26-04
04-25-22 09:34 AM - Post#2840299
    In response to Chevyfellow
Are you running original sealed beams or did you update to halogens?
Monty
2001 Chevy Suburban 2500
2009 Saturn Vue w/20's
Monty's 56 Truck
Avatar is my Truck
Chevyfellow
Reg: 04-09-22
04-25-22 09:38 AM - Post#2840300
    In response to monty56
Original repro t -3's.....
Mel Foye
Mel Foye
Reg: 09-29-00
04-25-22 11:34 PM - Post#2840335
Eng on, fast idle what does the amp meter show? If you step on the brake and the brake lights come on what does the meter do with the eng on and high idle? How many volts is your set up putting out?
It Was On Fire When I Laid Down.
grumpyvette
grumpyvette
Loc: farmersville texas USA
Reg: 03-16-01
04-26-22 01:19 AM - Post#2840337
    In response to Mel Foye
before you even try to start the car,get out your multi meter, your battery should read a bit more than 12 volts, once the engines at idle it should increase voltage and once your running at over about 1200 rpm you certainly should see a minimum of 14 volts from alternator.
obviously clean the battery cable contacts and electrical terminals and grounds,
related info and sub links
Edited by grumpyvette on 04-26-22 01:23 AM. Reason for edit: No reason given.
Mel Foye
Mel Foye
Reg: 09-29-00
04-26-22 06:24 AM - Post#2840342
    In response to grumpyvette
generator.
grumpyvette
grumpyvette
Reg: 03-16-01
04-26-22 12:08 PM - Post#2840352
then Id bsure verify the voltage and amps provided at idle, and in all likely hood you'll need a new battery and / or generator
TAT_2
Site Ambassador - Member #26 - "21st Year" Silver Supporting Member
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
04-28-22 04:12 PM - Post#2840430
https://www.motortrend.com/features/polarizing-g en...
09 PONTIAC- VIBE
08 PONTIAC- G6
93 VETTE - 40TH ANNIV- RUBY RED- LT1/6-SPD/RAG TOP
QUOTE FROM HELEN
05-01-22 11:24 AM - Post#2840533
is this a new problem or did you inherit it. my gut feeling is a wiring problem.
Chevyfellow
Reg: 04-09-22
05-09-22 10:51 AM - Post#2840931
Seems to stay at 12 even when increasing the idle speed..... I hear it should go to around 13....perhaps that is all the generator is capable of producing?
pauldian
pauldian
Loc: seligman,arizona
Reg: 05-14-09
05-09-22 08:20 PM - Post#2840947
If my memory serves me right ? When I had my 62 corvette the manual said it should charge at 13.5 volts. Should be able to have it checked at a starter alternator shop.
Remember,I'm not always right. But I'M never WRONG !
Mel Foye
Mel Foye
Reg: 09-29-00
05-11-22 10:13 PM - Post#2841076
I am NOT GOOD with electrical so I don't leave one lily pad until it is 100% right. I almost always start with the battery posts, record voltage. Next compare a post to it's cable. Any loss of voltage calls for reason of loss and correcting such dirty, too small of cable, loose etc. Are all connections snug?
I AM NOT TALKING ANYONE DOWN BECAUSE THIS IS JUST MY WAY OF NOT MISSING OR GLOSSING OVER THE REAL PROBLEM.
Are you using a multimeter as a place that uses--fine-- instead of measures such as 12.5, 13.4 tells me nothing.
I would leave engine off and high beams on for 20 minutes. What does battery voltage show & record what it shows at end of that twenty both with and with the lights off. Start eng with the lights on
and Meter hooked up. With both the drain from lights and the reduced reserve in the battery there should be a call for max voltage from the system. Use 1,2 --1,500 revs. Do headlights on a wall go lower or brighter with up and down on gas?
Mel Foye
Mel Foye
Reg: 09-29-00
05-15-22 08:36 PM - Post#2841243
Well what happened?
Chevyfellow
Reg: 04-09-22
05-16-22 08:38 PM - Post#2841312
I
Chevyfellow
Reg: 04-09-22
05-16-22 08:41 PM - Post#2841313
I went to a different shop with the generator and voltage regulator. It turns out generator was shot. Managed to locate what was needed locally, i installed it all and everything is working fine.The first place I went to checked it out and told me nothing was wrong..... hmmmmm...... thankyou for the help and advice!
Mel Foye
Mel Foye
Reg: 09-29-00
05-16-22 10:29 PM - Post#2841316
Yes when the first shop said you don't have to polarized for me it was he stepped into the batters box and I called strike THREE!!
Really thanks for getting back to here. Mel
Execution time: 0.394 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:02 PM
