chevy57ray
Reg: 06-20-21
04-24-22 01:25 PM - Post#2840260
355 cid SBC W/882 heads run Ok but température on exit at headers run about 420F except # 6 that shows 550F . Is there some things bad Somewhere ? I have the heads check up , nothing serious, change plugs, wires but still the same. Where should I look ? May leave it or try colder ac43 spark
Edited by chevy57ray on 04-24-22 02:31 PM. Reason for edit: No reason given.
04-24-22 02:25 PM - Post#2840262
In response to chevy57ray
Normally with everything running and tuned right exhaust temps don't vary by that much. But poor fuel distribution or a lean cylinder can cause this. If the car runs well, no sign of trouble and if you read the spark plug condition and it looks ok, leave it go.
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
04-28-22 02:38 PM - Post#2840421
I agree. Not sure on a carbureted engine what would cause that but perhaps a gap in the intake manifold where the engine pulls in air around that intake runner that isn't going through the carburetor.
Member #409
04-29-22 08:27 AM - Post#2840446
In response to Tony1963
100° temperature difference at idle is normal.
