Username Post: What is the fix for a very very sensitive horn        (Topic#368202)
carolinakid
carolinakid
Loc: Erwin NC
Reg: 08-27-03
04-18-22 07:00 AM - Post#2839989
The horn on my 56 is very very sensitive. You barely have to touch the horn ring to sound the horn. Remember reading that Another member was having the same issue years ago but can’t remember what the fix was. Could someone please refresh my memory. Thanks
04-18-22 09:57 PM - Post#2840028
    In response to carolinakid
a stronger spring? i would probly take it apart and figger a way to make the stroke longer by somehow shortening, or stretching something in there.
Edited by bobb on 04-18-22 09:57 PM. Reason for edit: No reason given.
carolinakid
carolinakid
Loc: Erwin NC
Reg: 08-27-03
04-20-22 01:42 AM - Post#2840075
    In response to bobb
The fix for my very sensitive horn was to loosen the three screws that hold the plastic ring with the three pedestals. I guess my idea of snug was too tight. If the screws are too tight as mine were the concave metal spring get compressed and the clearance between the spring contact and the concave metal spring gets smaller making for a sensitive horn. For info: the 16 inch steering wheel is a big improvement for driving comfort and getting in and out of the car.
Execution time: 0.194 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:38 PM
