longboard
"13th Year" Platinum Supporting Member
Loc: Grass Valley, CA
Reg: 09-20-04
04-16-22 11:46 AM - Post#2839885
Can you retro fit an electric fuel pump in an existing gas tank? Working on my wagon which has an odd shape and no one makes a replacement. Custom tank is big $$$. I have an electric pump mounted on the frame but want to move into the tank. So can that be done and have the necessary baffles?
Algoma56
Reg: 03-14-05
04-17-22 10:35 AM - Post#2839919
In response to longboard
Yes you can, several companies make retro-fit kits. Some need a flat surface to cut and drop a weld-in sleeve for the pump mount, others have a bolt-in, https://aeromotiveinc.com/product/universal-16- bol... but best to do some more research for your specific tank design.
5Larry7
"18th Year" Gold Supporting Member
Loc: Dallas, TX
Reg: 05-17-04
04-17-22 01:38 PM - Post#2839931
In response to Algoma56
X2. I have this pump in my car, fairly easy to install works great.
'96 Replica of a 1950's Teardrop Trailer. |
Old Buzzard
Loc: Madison, GA.
Reg: 10-13-07
04-18-22 08:22 AM - Post#2839998
In response to 5Larry7
No cutting welding etc.....
https://www.tanksinc.com/index.cfm/page/ptype=prod...
Chuck
Hotrodding and dragracing since 1955..
Injector inspector, and certifiable EFI nut.
Back to 55, again, for the 6th time.
