Username Post: Rear Sway Bar Question        (Topic#368158)
Kevin Blank
Reg: 10-01-20
04-13-22 04:52 AM - Post#2839736
I have an 80 Camaro that did not come with a factory rear sway bar. My frame has 2 holes on each side of the frame that look like the right location for a sway bar bracket. Can someone tell me what size bolts to use on those frame holes? It is hard to tell if those holes are threaded but I hope they are. I assume I can use them to install an aftermarket sway bar. Also, what sway bar diameter was factory? Thanks for the help. Kevin
04-17-22 10:51 AM - Post#2839922
    In response to Kevin Blank
what size is your front bar? if you get a rear bar that is too big you may need to upsize the front bar. if you want to upgrade cornering ability i might recommend getting a set of bars. especialy if your front bar is not at lease 1.125 diameter.
Execution time: 0.096 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:15 AM
