 Page 2 of 2 <12
Username Post: Header help        (Topic#367610)
1983G20Van
Loc: Hurst, Texas, USA
Reg: 11-13-02
03-17-22 05:04 PM - Post#2838286
    In response to 1983G20Van
This was the 97 van post thorley headers. Shifting at 4,800 rpm it still had good get up and go for a 4L85E and 3.73 gears. 2,000 rpm @65 mph up 6% grades in overdrive. I made a 2,200 mile road trip after the headers and averaged better than 19 mpg on every tank except one. I ran 90+ MPH for several hours on I-40 across TN outrunning a storm and still got over 17 on that tank.
https://youtu.be/-6DZhPN7VHQ
https://youtu.be/UgwvwHzk74c
Edited by 1983G20Van on 03-17-22 05:07 PM. Reason for edit: No reason given.
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
03-18-22 09:12 AM - Post#2838312
I'd be interested in your impression of the percent gains in horsepower and torque. Sounds impressive thus far.
1983G20Van
Reg: 11-13-02
03-19-22 05:34 PM - Post#2838397
    In response to Tony1963
Probably 8-10%. Was pulling 8-10% more air through the MAF at peak everywhere. Biggest airflow gains were in the 2,000-4,500 rpm range.
Been driving around the Pathfinder all week after the shorty header swap, it too has noticeably more acceleration at light throttle. Its definately more responsive everywhere. I notice it even at light throttle keeping up with traffic from a stop. I can keep pace with traffic with less throttle and the transmission upshifts earlier as a result. More torque = less throttle = less rpm = more mpg. No retune needed on the Pathfinder, just cleared the adaptive learning and let the ECU relearn the new airflow. Its MAF based with factory wideband 02s. I actually easily broke the tires loose this morning at half throttle. Individual tubes into a collector greatly help exhaust scavenging compared to a log manifold. Alot of my commute is between 30 and 55 mph. I find it staying in overdrive alot more even climbing grades and lightly accelerating. Before it took more throttle to hold the same speed and a slight increase in throttle forced it to kickdown a gear. Now using less throttle to maintain speed, it responds to light throttle changes with more torque rather than a downshift to get more torque.
Edited by 1983G20Van on 03-19-22 05:49 PM. Reason for edit: No reason given.
Fleetline49North
Fleetline49North
Loc: Hyas Sask Canada
Reg: 12-25-20
09-20-22 12:44 PM - Post#2847581
You might be right at the loose 20 lbs if u dump the stock exhaust manifolds . Also find they run much cooler on mine.
 Page 2 of 2 <12
Execution time: 0.146 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:00 AM
