Username Post: Questions regarding Jag suspension        (Topic#367523)
usmile4
"13th Year Gold Supporting Member
usmile4
Loc: Aurora, Illinois
Reg: 08-12-05
01-23-22 01:05 PM - Post#2835098
I know many of you have done the Jag front suspension and the idea keeps calling from deep in my mind. I have some questions and rather than ask these questions in one of the posts/builds some of you have posted, I thought I'd start another thread with just my questions:
1. I have in my notes that you can use a 73-79 Series II XJ6 or XJ12a or a 79-85 Series III. Lobucrod, I see that you used an 86, so my first question is: What is the complete list of years that will fit my 51?
2. I was under the impression that the Jag front end was the same fit as the stock 49-54. Flatout, I noticed that you narrowed the width, so my second question is: What is the width of the Jag?
3. I have a 235 in my 51. I have AC compressor and alternator on a modified Alan Grove bracket. Third question: Does anyone with the Jag front have a 235 with AC, alternator and power steering that can post some pictures?
4. I'm running bags on the modified stock front on my 51. Fourth Question: Is anyone running bags on the Jag front end?
Thanks for the help guys. Bill
Bill Gommel
flatout
flatout
Loc: Idaho
Reg: 12-15-01
01-23-22 10:26 PM - Post#2835141
    In response to usmile4
Mine was removed when I got it, but I ordered parts for a 1985 Jag XJ6 and they were always correct.
I can't find my original notes for the actual width, but I measured and triple checked the wheel mounting surface to wheel mounting surface on each one and found the Jag to be 2.5" wider.
I'll attached a picture of mine. It's a Patrick's bracket that I bought through Vintage Air.
Attachment: IMG_3276_4.jpeg (2.66 MB) 11 View(s)
usmile4
usmile4
Reg: 08-12-05
01-24-22 04:41 PM - Post#2835173
    In response to flatout
Flatout, That bracket set up looks pretty much like mine. I see from your build thread that you are not running power rack. I was wondering how I would bracket for the power steering.
Bill
Bill Gommel
Cruzin Okie
Cruzin Okie
Loc: Jay, Oklahoma
Reg: 10-26-11
01-24-22 09:40 PM - Post#2835185
The XJS is usable up through early 90s, same as the earlier XJs. I have an 89 XJS that I set up for my 53, 210.
Johnnie
1950 styleline deluxe sports coupe, 350 cid, TH 400, nova rear end. Gen IV Vintage air. SOLD!
1953 210 4 Door, 235 with Powerglide. All original except for the 1954 hood bird.
John 3:16
flatout
flatout
Loc: Idaho
Reg: 12-15-01
01-25-22 04:11 AM - Post#2835197
Bill
I don't know. That's a lot to hang off the front of a 235's stock front pulley and there's not any good mounting holes on the passenger side of the engine block. I know there are aftermarket crank harmonic dampers that have 2 pulley grooves.
Here is one place:
https://harmonicdampers.com/index.php?main_page=in...
You could look at www.davisspeedequipment.com to see about brackets.
Execution time: 0.097 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:19 AM
