Username Post: Traction bar question        (Topic#367484)
Rock49
Loc: Kansas City
Reg: 09-01-21
01-18-22 06:24 PM - Post#2834811
Am I understanding correctly?
You can use traction bars instead of swapping in wider springs when doing an axle swap.
High5
Loc: Washington State
Reg: 07-14-13
01-18-22 07:08 PM - Post#2834814
    In response to Rock49
Later model axle swaps have been done on 49-54 Chevy's without the need for changing leaf springs. You can add traction bars to eliminate leaf spring bending on acceleration. However you would need to include a floater kit to retain a stock ride.
The other option is to go with a 4 link suspension and eliminate the leaf springs all together.
1951 Chevrolet Sport Coupe 235 4 barrel 4spd
1954 Chevrolet 2dr Sedan Highboy 350 V8 set back 20% tilt front end '57 Olds rear 7" lift to front susp.
1955 Chevrolet 2dr Hardtop Highboy Olds tripower engine 4spd
1970 Corvette Stingray convertible
Edited by High5 on 01-18-22 07:14 PM. Reason for edit: No reason given.
Rock49
Loc: Kansas City
Reg: 09-01-21
01-19-22 05:12 PM - Post#2834886
    In response to High5
Thanks. That confirms my thinking.
Execution time: 0.095 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:23 AM
