Username Post: gear contact patterns        (Topic#367474)
56chev66must
Reg: 04-07-04
01-17-22 12:00 PM - Post#2834711
Hello guys,
Please take a look below and let me know if you think this pattern is good to go.
Thanks!
01-17-22 05:14 PM - Post#2834742
    In response to 56chev66must
When checking the tooth contact pattern, did you put a load on the ring gear as you rotated the pinion flange?
56chev66must
Reg: 04-07-04
01-17-22 07:32 PM - Post#2834750
Hello,
I think it's more accurate to say I put a load on both the ring gear and the pinion nut, that is to say I put a wrench on a ring bolt and a ratchet on the pinion nut and worked them both ways. But yeah.
Also, I looked at the pattern closely and made a command decision that the pinion was too close to the ring gear. I removed the pinion and bearing and changed the shim from .0365 to .032, rechecked and adjusted everything, and got these new patterns: How do they look?
stumppuller
stumppuller
Loc: Canada
Reg: 11-01-04
01-21-22 10:36 PM - Post#2835019
Pictures on your second post don't display for me. For me, the first pattern looked pretty good. It will be nearly impossible to achieve a "perfect" pattern.
On new gears, focus on the drive side. On used gears, focus on the coast side.
-91 Sierra C2500, now K2500
-81 Chev K20
Execution time: 0.136 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:18 AM
