Username Post: drain plug        (Topic#367456)
sanee64
Loc: atlanta ga
Reg: 04-05-18
01-14-22 07:37 PM - Post#2834554
When i gave my car its first oil change the drain plug was semi stripped already, had 2-3 plastic washers on it and some kind of sealant on it. It leaked very little but nothing to really worry about. Fast forward to couple days ago needing to do another oil change i had to take care of this problem.
Plan was to tap a bigger hole for an oversized plug. Pain in the arse as the placement of the drain hole and tap hits the frame just a tad. After much cussing i tapped it but now it still leaks (prob more than before)
I tried the washer supplied with the new plug (cork like) first then a soft metal one and still same results.
My threads probably arent the best as i was hard to tap it going in straight. What are my options? A quick search and theres a drain plug sealant?
Stittville Ed
Reg: 01-10-16
01-15-22 07:45 AM - Post#2834565
    In response to sanee64
If you can find a Old School Parts Supply House they may be able to help.
All the Chain stores will most likely just have Metric.
Or a old Repair shop.
The Quick Change Oil place must strip a lot of them so I might ask them, but never let them do the work.
Tony1963
Loc: Orlando Florida
Reg: 07-09-18
01-15-22 08:31 AM - Post#2834566
I've never seen much of a fix on this issue. Not only are the threads ruined, the pan is probably deformed around the drain hole.
If you can get one to work and it is close to the frame, I'm wondering if your motor mounts are sagging?
In a prior life we replaced hundreds of oil pans due to the kind of thing that you are describing. The steel ones are more forgiving but forget about aluminum and otherwise.
I'm suggesting a new oil pan if you want to go that far.
sanee64
Loc: atlanta ga
Reg: 04-05-18
01-15-22 10:03 AM - Post#2834574
    In response to Tony1963
Im literally trying everything to not have to replace oil pan as it seems to be a bit of a pain. I just tried the drain bolt sealant and didnt work worth a damn.
im thinking of jb weld the damn thing as im getting tired of dealing with it. When time comes for another oil change, i just drill another hole and tap it. Or hopefully ill have to drop the engine by then to do a complete rebuild of the car by then
Tony1963
Reg: 07-09-18
01-15-22 10:51 AM - Post#2834575
The factory and replacement pans have a steel fitting spot welded on the inside of the pan where the bolt threads into. You cannot simply drill a hole and thread the sheet metal.
Member #51
01-15-22 11:36 AM - Post#2834581
If you want to retain your original pan (AND I WOULD), the ONLY, repeat, ONLY sure fire cure is to remove the pan (YA, YA, YA, YA, I KNOW IT'S A PAIN), remove the old threaded nut inside and weld in a taller nut with more, fresh threads. Then drill a hole in 2-3 flats of the nut so that most of the oil will drain.
This not an oil pan, it is a rearend that I welded a nut on the inside. The principle is the same.
Attachment: 100_2922-1.jpg (52.63 KB) 16 View(s)
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
01-15-22 02:16 PM - Post#2834587
If memory serves me right they used to sell oversized self tapping drain plugs just for that reason.
Such as these:
https://www.ebay.com/itm/115171246951?hash =item1ad...
Member #51
01-15-22 02:37 PM - Post#2834592
    In response to turbo38s10
Such as these:
That is EXACTLY correct. I'm kind of surprised that has not been mentioned.
sanee64
Loc: atlanta ga
Reg: 04-05-18
01-15-22 06:48 PM - Post#2834605
Such as these:
i actually bought that also. funny part is the new drain plug fits but not this and its the same size. ill mess with it again tomorrow
chopr1
chopr1
Loc: Copan, Oklahoma
Reg: 01-11-19
01-16-22 01:01 AM - Post#2834617
Had the same problem, and did buy an over size kit. (they come in different sizes as I remember) BUT, retapped, still leaked, got it to stop for this oil change. Procrastinating before the next change. Sorry for no help. If you don't find an answer from the fellows on this forum, it is a tough nut to crack, so to speak!!!!!
Levon
Loc: NY
Reg: 05-06-09
01-16-22 03:12 AM - Post#2834619
    In response to chopr1
They used to sell a rubber drain plug with a plastic adapter in the help section of auto parts stores. You push the rubber into the oil drain hole, twist and release. It expanded inside the drain plug hole. The rubber looked like a baby bottle nipple. That's what I used on my 1966 Impala stripped and it never leaked.
sanee64
Loc: atlanta ga
Reg: 04-05-18
01-16-22 07:20 AM - Post#2834627
    In response to Levon
what voodoo magic part is this called??
1941srodcoupe
Reg: 07-08-03
01-16-22 08:29 AM - Post#2834630
Now that you have the leak stopped you can treat it like a boat engine. Buy a siphon kit that remove the oil through the dipstick tube. They are about $80 and come in handy for many other things. I have used it on a few cars then pulled the drain plug just to see how much oil it missed. I'd say less than 2 ounces.
Tony1963
Reg: 07-09-18
01-16-22 10:47 AM - Post#2834638
    In response to 1941srodcoupe
Many European car makers also specify the vacuum method. They all provide a drain plug, too.
Any sediment comes out the drain plug. I am not a fan of the vacuum method for that reason.
I always pull the drain plug on my Mercedes vehicles.
1941srodcoupe
Reg: 07-08-03
01-16-22 11:02 AM - Post#2834642
I agree. but if it thorouhgly heated there shouldn't be hardy any sediment. Unless it's a nasty caked up mess inside already.
Tony1963
Reg: 07-09-18
01-16-22 11:14 AM - Post#2834643
You are correct. I find that pulling the drain plug is easier.
01-16-22 11:27 AM - Post#2834646
try wrapping the plug close to the head with a bunch of teflon tape. next oil change make sure to get all the tape out of the hole. i have seen this work a bunch of times.
55Brodie
Loc: Little River, SC
Reg: 12-26-15
01-16-22 01:57 PM - Post#2834653
Google Loctite 236382.
Tony1963
Reg: 07-09-18
01-16-22 02:51 PM - Post#2834657
    In response to 55Brodie
Plumber's putty mixed with Sakrete.
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
01-16-22 07:42 PM - Post#2834672
Never fails! I used one of those on my '71 New Yorker many years ago...worked great but I probably wouldn't on a classic now days unless as a temp fix till I could remove the pan and do a proper fix or replacement.
Dorman 091-044 on eBay along iwth a few other mfrs.
Steve
327 / 300 L74
M11 3 on the tree
12 bolt 3.31 open dif
Edited by docjns1 on 01-16-22 07:47 PM. Reason for edit: No reason given.
55Brodie
Reg: 12-26-15
01-17-22 12:01 AM - Post#2834683
Oh, so now you're a chemist, too?
01-17-22 08:00 AM - Post#2834696
lol
sanee64
Loc: atlanta ga
Reg: 04-05-18
01-17-22 03:19 PM - Post#2834727
    In response to bobb
well that didnt work
sanee64
Loc: atlanta ga
Reg: 04-05-18
01-17-22 03:21 PM - Post#2834728
    In response to docjns1
https://www.ebay.com/itm/142329162906
this thing?
sanee64
Loc: atlanta ga
Reg: 04-05-18
01-17-22 03:22 PM - Post#2834729
oh nice and well worth a shot. thanks
sanee64
Loc: atlanta ga
Reg: 04-05-18
01-17-22 03:28 PM - Post#2834731
ill hit ya up if i need a margarita
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
01-18-22 09:37 AM - Post#2834775
Here is a double oversize:
https://www.ebay.com/itm/154498520709?epid =1022876...
1941srodcoupe
Reg: 07-08-03
01-18-22 12:16 PM - Post#2834783
I think that's what he is talking about. I've had to use those back in the 70's & 80's they work quit well.
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
01-18-22 04:12 PM - Post#2834804
thats the one, though there are several similar in design and function
Steve
327 / 300 L74
M11 3 on the tree
sanee64
Loc: atlanta ga
Reg: 04-05-18
01-18-22 07:20 PM - Post#2834817
  • turbo38s10 Said:
I think im going to go this route as i already have this. Just got to make sure it goes in right as i tried it couple days ago and was having a hard time trying to get it to start.
The thread sealant is going to be messy and having to make sure the drain hole is super clean which is gonna be tough.
Got tonite to think bout it, then ill try it tomorrow. What say you guys?
Execution time: 0.134 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:47 AM
