Username Post: Hubcap removal on 1959 impala        (Topic#367450)
draggin49
draggin49
Reg: 06-14-14
01-13-22 10:40 PM - Post#2834515
So I bought a hubcap removal tool with the rubber hammer on backside . The caps on my 59 are so snug to the steel wheels the removal blade part you use to get under and pry the cap off won’t even fit in there. I’ve never had a vehicle with caps be this difficult to get popped off . One of my center caps came loose and it’s rattling around . Any tips or ideas of what to try since the tool won’t fit under the caps ? I guess I could try and file down the hubcap removal tool so the blade is almost like an axe blade on the end to try and fit in a tighter spot.
Mercedes
Loc: Orlando Florida
Reg: 07-09-18
01-14-22 06:32 AM - Post#2834521
    In response to draggin49
Myself I never had that tool for the same reasons that you are describing. With the hub caps being a pressed fit, you are undoubtedly going to have to pry on something to get the cap to move.
I used to wrap blue painter's tape on the end of a flat blade screwdriver to not mar the paint and that seemed to work. Added a cushion to the otherwise sharp end.
01-14-22 08:36 AM - Post#2834526
    In response to Mercedes
Same here
draggin49
draggin49
Reg: 06-14-14
01-14-22 09:54 AM - Post#2834532
Thanks guys , I have tools at my other house . I will try and go by there and see if I got a nice flat blade screwdriver and I will try the painters tape. Thanks for the tip!
Haha I guess the hubcap tool will just be used for the rubber end to put them back on
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
01-14-22 12:13 PM - Post#2834537
The screw driver should work. But, your 'mod' (filing your current tool) might actually be a slightly less risky option. The 'blade' is slightly wider and that might reduce the risk of damaging the wheel cover (think less 'psi').
Also, I could control the 'force' applied little better, and get a little more leverage with something like that (compared to a screw driver).
That would also reduce by one the number of tools you carry.
If I was going to carry a separate tool for the job, I'd likely choose something like this:
https://www.homedepot.com/p/Milwaukee-12-in-Pry -Ba...
Simply options.
Pete
PLS
PLS
Loc: Smyrna, Georgia
Reg: 06-07-12
01-15-22 12:08 PM - Post#2834585
This is the tool that I use to remove my wheel covers, similar to the one Pete mentioned.
You said hub caps so I don’t know how it would work on them.
Each time before I take the 60’ out I use a rubber mallet and go around and make sure each cover is snug because usually after an outing most of the time I notice a spot somewhere along the edge, the cover has crept out so slightly.
If I want to remove the cover, I will turn the wheel around to one of those spots and use the tool shown to remove the cover. I have a small piece of soft wood that I put behind it and after moving it a few times around the edge the cover pops off.
I don’t know if your are cap or covers so not sure that this would a solution for you or not.
I know that I have always call them hub caps and some have been corrected here CT for that, but I have also always called a circular saw, a Skill saw, an adjustable wrench, a Crescent wrench and etc.
Good luck with them. Lamar
Let us know what works, it may help other later.
Attachment: IMG_0756.JPG (623.21 KB) 0 View(s)
Lamar
My ’60 Chevy history video: https://www.youtube.com/watch?v=kuLdKs2Gp5k
64ss409
Reg: 12-04-02
01-20-22 10:33 AM - Post#2834935
    In response to PLS
I have had trouble getting the stock SS hubcaps off my 64. They dig into the wheel pretty hard. I use a tool similar to the one below with pretty good results.
Pry bar
1962 SS convertible, 327/250 4 spd
1956 IH pickup, 327
Execution time: 0.609 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:48 AM
