Danchuk
Username Post: 1956 Front Wheel Bearings        (Topic#367414)
stano
stano
Loc: Iowa
Reg: 12-30-00
01-09-22 11:26 AM - Post#2834215
On 1956 front wheel bearing is there a way to get roller bearing set up with stock spindles and stock drum brakes.
thank you stano
thank you
stano
Mercedes
Loc: Orlando Florida
Reg: 07-09-18
01-09-22 02:27 PM - Post#2834240
    In response to stano
Aren't they roller bearing from the factory? They're not ball bearing are they?
Not an expert but wouldn't think that they used ball bearings on front wheels.
55MAS
Loc: North Coast, USA
Reg: 12-19-01
01-09-22 02:57 PM - Post#2834244
thank you stano
The original bearings are BALL bearings. If you want to keep the drum brakes buy a pair of 61-68 Impala/Belair front hubs. These have TAPER ROLLER bearings. Get a new set of bearings and seals and reassemble like original. EXCEPT - roller bearings are adjusted a little differently. Check a '61 up service manual. Alternately you can buy a new set of aluminum hubs at considerable more expense.
Mercedes
Reg: 07-09-18
01-09-22 03:59 PM - Post#2834250
    In response to 55MAS
Wow - I learn something everyday.
Member #409
01-09-22 05:50 PM - Post#2834264
    In response to Mercedes
personal attack removed
Edited by Tony on 01-10-22 08:40 AM. Reason for edit: No reason given.
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
01-09-22 10:08 PM - Post#2834269
    In response to Rick_L
You do not have to buy anything to have roller bearings, except the bearings, and races.
Check --fillingstation.com
The box mine came in said they fit 40-59 Chevrolet cars and trucks, and 38-60 GMC trucks-54-62 Corvette someone should be able to cross reference them, to be sure.
Or go to classic performance parts for $90 for all of them with free seals
1952 Styleline Sedan, 62-235, Drum brakes, Manual steering, 2" Drop, 8-60 AC, Glass packs, Two Carbs, and a Cast Iron PowerGlide-
Way out behind the Old School
Half a Dozen in a Row, all it needs for Her to go.
Edited by gcrkfrd on 01-09-22 11:20 PM. Reason for edit: editted this post three times
Mercedes
Reg: 07-09-18
01-10-22 01:58 AM - Post#2834272
We can all do without the personal attacks, thank you very much.
Edited by Tony on 01-10-22 08:46 AM. Reason for edit: No reason given.
01-10-22 08:45 AM - Post#2834291
I'm growing tired. The delete button is next then I guess I have to be thrust back a decade and need the ban button.
I just can't believe the way people are not responding to my requests.
That was my final warning to anyone who wants to name call or bully someone on this site.
Edited by Tony on 01-10-22 08:48 AM. Reason for edit: No reason given.
Execution time: 2.498 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:44 PM
