Gold and Platinum Members will see no ads here.
Username Post: Search Tool - Using our unique search engine.        (Topic#367395)
01-07-22 10:21 AM - Post#2834037
I know its old but so are our cars, give it a shot I promise it does work. Find the blue SEARCH button across the top.
1. Select the forum. Unless you are a supporting member you can only select one forum at a time. In this case we have selected 1958-1960.
2. We are searching for the term floor braces so that phrase needs to be surrounded by "" as in "floor braces"
3. Select the Boolean mode. If it was a single word you would select normal.
4. Select the dates you wish to search. NOTE searches are limited to 500 so you may have to get creative to come in under that value.
The other options should be self explanatory.
If you need help just ask and we should be able to post a screenshot example for you.
Attachment: 2022-01-07_10-03-09.jpg (251.09 KB) 16 View(s)
Execution time: 0.95 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:40 PM
