Username Post: 53/54 vent tubes        (Topic#367372)
kool53
Loc: Mukwonago, WI
Reg: 06-18-04
01-05-22 07:53 PM - Post#2833930
Looking at restoring the vent tubes under the hood of my '53 and was wondering what some of you have done to replace what I believe is some kind of heat absorbing material inside? Did you just go without or use something else after tearing out the old stuff to paint them?
eplantage
Loc: Southern MN
Reg: 03-15-04
01-10-22 12:55 PM - Post#2834311
    In response to kool53
I left them as they were. It's in there to insulate them either from engine heat cooling the fresh air from the outside or transmitting engine noise into the passenger compartment. A similar type of insulating panel is on the back of the dash access panel above the steering column in the engine compartment to keep engine heat out.
Age: 67 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
Member #51
01-10-22 01:09 PM - Post#2834312
    In response to eplantage
Back during the Civil War days, I removed the vent tube on the 51 (ONLY on driver side, heater is on pass side), and it also had the insulating material material inside. I could not come up with a material or method to replacement, so I just left it out. Actually, I cannot tell any difference.
belairbob50
Loc: OH where rust never sleep...
Reg: 03-17-13
01-12-22 05:11 PM - Post#2834453
Hey Kool 53, can you do me a favor. Can you measure the distance across the open end of the fresh air vent tube at the radiator end? Thanks
kool53
Loc: Mukwonago, WI
Reg: 06-18-04
01-12-22 05:43 PM - Post#2834456
    In response to belairbob50
5 1/4"
belairbob50
Reg: 03-17-13
01-12-22 06:40 PM - Post#2834458
Kool 53, you just made my day. I have had a pair of sheet metal panels with the screens that the fresh air vents attach to for 30 years. I bought them for my 1950 BUT the vent tubes are 4 1/4" - not 5 1/4". The original wire tags that were attached to these panels showed a part number of 385483. If you look that number up, it is for a 1964 Olds Delta 88 3 seat station wagon carpet option. Now I can honestly sell them as a 1953-54 part. Thanks again.
[image]https://[/image]
kool53
Loc: Mukwonago, WI
Reg: 06-18-04
01-13-22 04:12 PM - Post#2834503
Well, I hate to be the bearer of bad news...
It's a little hard to tell from the angle at which that photo is taken but I'm fairly certain those are not '53 Chevy panels. They do look like they could be '54 but someone with a '54 would need to confirm. '53 and '54 are definitely different due to the wider grille opening in '54.
Edited by kool53 on 01-13-22 04:14 PM. Reason for edit: I'm a bad speller!
54delivery
Loc: Salem, OR
Reg: 11-19-13
01-13-22 05:24 PM - Post#2834506
It is difficult to see from that single photo because they are pictured upside down and swapped side for side of how they appear on the car...but, after looking at my 54 in the shop just now, and also comparing a pic I have with fenders off, I'd say they certainly could be 54 panels. A better picture could confirm what you have.
Edited by 54delivery on 01-13-22 05:28 PM. Reason for edit: I'm a worste speller
belairbob50
Reg: 03-17-13
01-13-22 06:20 PM - Post#2834507
    In response to 54delivery
I found a photo taken of a CT member's 1953 Bel Air. The driver's side panel is taken along with that photo. Not being familiar with the difference between a 53 & a 54, what should I look for or measure to confirm which year they fit? Thanks
kool53
Loc: Mukwonago, WI
Reg: 06-18-04
01-14-22 03:07 AM - Post#2834518
In the inset photo where it shows it mounted on the car, notice the shape of the bottom of the panel. See how it bends down at an angle towards the outside of the car and has four holes to mount the splash pan. - that is'53. In the picture of your panel, it looks straight across with an upward notch on the right side. Again, not '53 but possibly '54.
Anyone have a '54 they can compare this to?
54delivery
Loc: Salem, OR
Reg: 11-19-13
01-14-22 08:16 AM - Post#2834525
BelairBob's last pic looks just like the panel on my 54.
Edited by 54delivery on 01-14-22 08:19 AM. Reason for edit: No reason given.
alltak
alltak
Loc: dallas texas
Reg: 10-04-04
01-14-22 08:04 PM - Post#2834558
Looks like a 54 to me...
Attachment: IMG_0763.jpg (2.19 MB) 6 View(s)
belairbob50
Reg: 03-17-13
01-15-22 05:30 AM - Post#2834563
    In response to alltak
Thanks Kool 53, 54 Delivery and Alltak for your help. I've had these panels since just after dirt was invented. They were sold to me for a 1950 - WRONG. So now I can find them a 1954 home. Thanks again for the help.
Execution time: 0.72 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:34 PM
