Username Post: New heater motor shaft size bigger than fanblades collar        (Topic#367190)
CurtisLee
Reg: 01-17-16
12-14-21 04:09 PM - Post#2832522
Purchased new motor for my 1950 Chevy 3100 found that the shaft size is 5/16" while the collar on the four blade fan is 1/4". Cataloge say product may need some slight modifications to work. Has anyone come across tis problem? How did you correct it? The only small modification I made was drilling bolt holes larger to mount the motor. I did drill the collar out on the fan but destroyed the mounting sleeve holding the collar onto the fan blades and now I'm $%#^ed. Thanks. (hope there's someone in CT World working on origional equipment)
I was able to fix the problem so disreguard.
Edited by CurtisLee on 12-17-21 08:35 AM. Reason for edit: No reason given.
Member #189 Moderator and "20th Year" Platinum Supporting Member
12-23-21 01:56 PM - Post#2833129
    In response to CurtisLee
How did you fix the problem?
29-41, 42-48, 49-54 Moderator
CurtisLee
Reg: 01-17-16
12-25-21 01:02 PM - Post#2833225
Used a new 3/8" collar (hole size) and a piece of steel tubing (used in electric lamps to run the cord through) since it was 3/8" outside diameter and drilled inside out to 5/16". Drilled the fan blade base hole out to 3/8". Cut the tubing for the length, about an inch, that needed to go through the collar and fan blade and allowed about a 1/16"+- to stick out above the fan blades base in which I peened this edge out to hold the fan blade to the collar mount (also drilled a hole in the tubing for the collar set screw to go through for securing the fan blades to the motor shaft). Mounted this assembly to the 5/16 shaft of the motor and had a good fit, tested and seemed to work ok.
01-09-22 03:04 PM - Post#2834237
Good job.
Execution time: 0.195 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:20 PM
