Username Post: Tire Pressure Monitors        (Topic#367121)
Redspad
Redspad
Loc: South West Florida
Reg: 08-15-09
12-06-21 04:22 AM - Post#2831996
Question; I was showing a low tire pressure on the right front tire. In checking them I found that tire was ok but the left front was the one that was low. How do I get the monitors back in sync so they read the right tire.
12-06-21 07:53 AM - Post#2832015
    In response to Redspad
What model and year? It's probably not an S10. Other models require starting a learn procedure. Air must be taken out of the tire, then inflated back up.
'08 GMC Acadia 3.6L SLE
12-06-21 03:06 PM - Post#2832044
A high line scanner can reset most tpm systems, some vehicles have an onboard relearn function also.
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
12-07-21 08:28 AM - Post#2832084
Switch the tires....
Redspad
Redspad
Reg: 08-15-09
12-16-21 04:10 AM - Post#2832609
    In response to Stinky
I never gave this a thought, but would rotating the tires be my problem and if so how do I get them back in sink
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
12-16-21 11:29 PM - Post#2832682
It could easily be the problem. As to getting them back to where the computer thinks they are, force any given tire to go low. It should trigger the computer to tell you. Put some masking tape on the tire to mark which one the computer thinks it is and then move them accordingly. Air each one back up to operating pressure as you go and you’re good.
Greg
‘01 Silverado 2500HD 8.1/Allison 1000 Xcab/LB
'00 Explorer XLT 4.0 SOHC V6 Auto
'95 K1500 Z71 EC Short Step 5.7L+0.040/NV3500 SOLD
Mercedes
Loc: Orlando Florida
Reg: 07-09-18
12-17-21 02:41 AM - Post#2832684
I'm trying to recall if this vehicle has tire pressure sensors or if the low tire pressure is through the ABS system, calculating fewer revolutions per mile on a low tire?
12-19-21 04:03 AM - Post#2832846
    In response to Mercedes
What's the make and model?
Mercedes
Reg: 07-09-18
12-19-21 11:06 AM - Post#2832881
I do not see any reference to the year, make or model in the thread.
Redspad
Redspad
Reg: 08-15-09
12-29-21 08:09 AM - Post#2833405
2015 Chevrolet Colorado LT, 2wd, auto
Mercedes
Reg: 07-09-18
12-29-21 09:21 AM - Post#2833422
That model has pressure sensors in the wheels. The low frequency signal it sends are picked up by a receiver nearby. From what I know, driving a distance it will pick up the signal from the sensor and know the pressure.
12-30-21 04:17 AM - Post#2833462
"2015 Chevrolet Colorado LT, 2wd, auto"
Unfortunately, GM went to a more difficult way to reset tire pressure monitors in '15. There are two levels. Base and UpLevel displays. The UpLevel has steering wheel buttons. You'll need a basic TPMS tool. The tool will activate the sensor for reading. A simple activation tool will work.
Mercedes
Reg: 07-09-18
12-30-21 01:08 PM - Post#2833498
Wow - good to know. My Mercedes will relearn the tire pressure if you move the wheels. Mine are different size front/rear but it has a receiver for each sensor.
12-31-21 04:04 AM - Post#2833534
My Acadia has a semi difficult one. You have activate the system to learn. Once in learn mode, you have to remove and add air to each wheel. I'll be doing it soon. The same tires read differently on the instrument cluster and aftermarket radio. I added the buttons for cluster readings. Plus added buttons to add "tow" mode.
Redspad
Redspad
Reg: 08-15-09
01-20-22 03:25 AM - Post#2834903
Thank you sir, I got this tool and a little investigating I found out how to get it in the mode I needed so I could reset the monitors. It worked perfectly
01-20-22 06:43 AM - Post#2834914
Good info to know Redspad. Thanks for following up. I’ll probably buy that tool. Cheap enough to keep in a tool bag.
Execution time: 2.66 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:50 PM
