Username Post: lifters        (Topic#367043)
otis3
Reg: 04-29-14
11-25-21 04:27 PM - Post#2831437
is there a way i can tell if i have solids or hyd lifters without pulling intake.i have a wire camera.maybe type of clip on top of lifter
11-25-21 05:53 PM - Post#2831440
    In response to otis3
Ok, what engine?
otis3
Reg: 04-29-14
11-25-21 08:11 PM - Post#2831443
chevy 327
Rick Dorion
Rick Dorion
Loc: Accord, NY
Reg: 09-21-12
11-26-21 03:38 AM - Post#2831446
Take a valve cover off, bring one lifter on a cylinder to the base circle of the cam and see if you have any clearance at the rocker arm tip.If there's a preload you most likely have hydraulic. Is the car running smoothly? Have a sewing machine sound?
1967 Belair - LM7 5.3, Autogear M23Z, Global West, C5 brakes and rims.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
11-26-21 06:44 AM - Post#2831448
Simply listen for the normal 'clatter' the solid lifters make. Their 'noise' is quite distinctive. The 'frequency' (not hertz, just how often) of the clatter will rise and fall with rpm.
Hydraulic lifters are mostly silent unless 'stuck', or out of adjustment. Typically that's an individual lifter fault; 'clatter' is not a 'normal' noise of the 'system'.
Pete
Execution time: 0.14 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:55 AM
